I haven't changed the thermostat or water pump since i got the car. Would this be a problem??
Coolant in the reservoir is at MAX mark and in the radiator it's not filled to the neck because it just goes in the reservoir is that okay?
notnilc20 wrote:The thermostat could be seized shut. Try that first......you can remove it and put it in some boiling water and see if it opens up before buying a new one.
SgtRauksauff wrote:how far down in the radiator is the coolant? it should be at least up to the nozzle that goes to the overflow tank. If it's not, you might have an air pocket in the coolant system, which can also cause inaccurate temp readings.
But I'd say first stop is a thermostat check. they're relatively cheap, so if you're opening up the housing to look at one, it's easy-peasy to put in a new one anyways.....
Also, what's your coolant mixture like? have you tested it with a hygrometer to make sure it's a decent mix?
--sarge
Swooki wrote:Since i'm taking it out shouldn't i just get a new one? Which one is recommended?
