15x7 +40 4x114.3 Slipstreams on 86 GT-S
CloudStrife
Postby CloudStrife » Thu Jan 04, 2018 1:30 pm
Hey guys, I'm not good with tire stuff, and I bought a set of rims that I just love for the price and weight.
https://www.ebay.com/itm/15X7-40-SLIPST ... 2749.l2649
I knew I would need spacers, and I test fitted on the front, and it sits too close to the inside, almost hitting the strut.
So I was wondering what you guys would recommend?
I was thinking about these:
https://www.ebay.com/itm/Phase-2-15MM-B ... 1438.l2649
jdm86gtz
Re: 15x7 +40 4x114.3 Slipstreams on 86 GT-S
Postby jdm86gtz » Thu Jan 04, 2018 1:45 pm
Using this:
http://www.1010tires.com/Tools/Wheel-Offset-Calculator#
and inputting the stock 14" Intra wheel spec of 6j +21 against yours, you need 32mm of spacing just to match the inner wheel to strut clearance.
CloudStrife
Postby CloudStrife » Thu Jan 04, 2018 2:03 pm
Thank you for the quick reply sham.. That is a massive spacer, no?
I've seen 30mm spacer: https://www.ebay.com/itm/Phase-2-30MM-B ... 0005.m1851
But 32mm seems like a unique number. Off-the-shelf spacers seem to run in multiples of five...
Postby jondee86 » Fri Jan 05, 2018 1:17 am
If you can fit those rims without them binding on the struts you are doing OK :)
For OEM style RWD 7" rims on an AE86 the offset would usually be in the positive
5 to 10mm range. You are at 40mm positive, so yeah, the rim is about 30 to 35mm
further inboard than ideal. If you use a 30mm spacer you should be fine, as the
extra 2mm is not going to change things worth a damn.
If you plan tp have the car low (top of the tire tucked) it would pay to experiment
with some kind of temporary spacer so that you can fit the rim to the car and check
how much clearance you have to the guards. Check front and back before you decide
on what spacers to buy. You don't want to find that you have guard rub once you
drop the car down on a new set if tires !!
CloudStrife
Postby CloudStrife » Fri Jan 05, 2018 9:47 pm
Thanks Jondee, thats what I ffigured. I'm just gonna return them though and keep my ugly Rewinds, I don't like running spacers personally.
Postby jondee86 » Fri Jan 05, 2018 9:59 pm
Good decision. I'm not a fan of spacers either, although I did have a set of 25mm
spacers that I used to make a set of 5-1/2" +27 OEM Toyota rims look better on the
car. Now I just use 6" or 6-1/2" RWD rims and forget about getting them flush :)
CloudStrife
Postby CloudStrife » Fri Jan 05, 2018 10:08 pm
Haha, same here. I appreciate the info however, for future reference and other members.
Jayrdee
Postby Jayrdee » Sun Jan 07, 2018 4:48 pm
A little off subject, but whenever I'm in the market for wheels, I use this website a lot. I'm more of a visual type of guy.
http://www.fitmywheels.com/
_____________________
instagram: @dacobjurbin
CloudStrife
Postby CloudStrife » Mon Jan 08, 2018 12:38 pm
That's dope man, thanks a bunch.
