Work Equip 03 + T3 baby daddy brake kit
yabaiani
Postby yabaiani » Sun Oct 20, 2019 8:37 pm
Hi everyone! Just wanted to ask what the best wheel size, offset, and disk type to select from for a set of work equip 03s. I would be running just shocks and springs, so no major modifications to suspension or body.
I didn’t know if the T3 baby daddy kit in the front would cause problems for the work wheels, and if not, then which is the right type to get (a disk, o disk). Also, does anyone know if I get the rear big brake kit from T3, what would be the best on that?
Thank you all in advance!
idreamofdrifting
Re: Work Equip 03 + T3 baby daddy brake kit
Postby idreamofdrifting » Sun Oct 20, 2019 10:48 pm
what engine do you have that would justify you running a bbk?
yabaiani
Postby yabaiani » Mon Oct 21, 2019 2:57 am
idreamofdrifting wrote:what engine do you have that would justify you running a bbk?
Just the regular 4AG, but it already has the T3 kit so that’s why I was asking. Not for the rear though.
aukword1
Postby aukword1 » Mon Oct 21, 2019 7:45 am
If you contact T3 they can send you a wheel fitment template for that kit. I have the big daddy brake kit from T3 and it will fit 15x8 0 offset just fine. Since you have the baby version, you probably have more options when it comes to offsets and sizes.
Nick94tt
Postby Nick94tt » Wed Oct 23, 2019 5:23 pm
A worn out low compression stock one?
yabaiani
Postby yabaiani » Wed Oct 23, 2019 8:02 pm
that very same one :)
Ava92
Postby Ava92 » Wed Jan 01, 2020 10:54 am
Wondering the same with CR-01 15" and the older wilwood 4pots. Would like to order o-disk but worried it will hit the caliper. :(
Wish Work offered this information on their website. The chart only shows lip size. I am waiting to hear back from them.
