Koyo Radiator + stock fan
Posted: Wed Jan 01, 2020 9:28 pm
by yabaiani
Hi everyone. Just wanted to ask if the Koyo radiator works with the OEM fan + shroud or do I have to put on the Mishimoto dual fan?
Re: Koyo Radiator + stock fan
Posted: Thu Jan 02, 2020 6:50 pm
by jondee86
I believe that the KOYO radiator has lugs at the bottom and fixing points at
the top to allow you to use the OEM fan shroud and viscous fan. However, as
the KOYO is thicker than the OEM radiator, the shroud will sit a little closer
to the engine so you would need to check just to make sure that there are
no clearance issues.
Posted: Sat Jan 04, 2020 12:15 pm
by yabaiani
jondee86 wrote:I believe that the KOYO radiator has lugs at the bottom and fixing points at
Thank you so much. It bolted it in with no issues.
Posted: Wed Jan 29, 2020 12:30 pm
by mad_86
Yes koyorad is a stock replacement so everything should fit with oem parts
