This weekend (weather permitting), I will be Installing a new rear window seal for my AE86 coupe. I had a couple of questions before i start.
I will probably cut the existing window seal out since i have a used and brand new one.
Rust has developed in the 2 bottom corners of the rear window area. I have purchased a por-15 starter kit to remove, stop and prevent future rust from forming (hopefully)
I will Bondo over the treated area to make it nice and smooth then paint over that to finish.
When re applying the window seal, does anyone have any suggestions or advise on how to do this? Also, what kind of sealant should be applied under the weather stripping to make a tight seal?
Any advice on this topic would be greatly appreciated. this is my first time replacing a rear window seal so would like to be prepared ahead of time.
