Head build
theshaw0000
Head build
Postby theshaw0000 » Tue Feb 19, 2013 10:39 pm
Whats everyone using for valves springs retsiners etc. like brand names i currently have a jdm redtop large port
Toyoloog
Re: Head build
Postby Toyoloog » Wed Feb 20, 2013 12:32 am
It depends on what cam's you will be running to be honest.
No need to run the Formula Atlantic dual TRD valve springs with stock cams.
With stock cams I'd just run the OEM springs or are you raising the rev limit as well?
Most common brands are HKS, Toda & TRD. I see more and more supertech parts as well but I don't know the quality of them.
theshaw0000
Re: Head build
Postby theshaw0000 » Wed Feb 20, 2013 7:22 am
Wanna raise rev limits of the car i want it to be able to rev to 10k all day no probs
Re: Head build
Postby oldeskewltoy » Wed Feb 20, 2013 2:42 pm
theshaw0000 wrote:Wanna raise rev limits of the car i want it to be able to rev to 10k all day no probs
then spend $5000-$7500 and get Loynings, or Hasselgren to build it for you.....
in most cases(90% of all 4AG engines) very little in the way of cylinder head parts are needed to make a lot more power then stock.
For example... I'm making about 170hp(145 @ the wheels), I have a mild cam("264 type"), and simple uprated single valve springs. The valves, and guides are all stock units, they have had a professional go over them and improve their operation, but most of the head parts are OEM.
PS - rev all day at 10k... means you are also going to need a $5000 dry sump system, as well as around $8000 to $10,000 for the engine internals
Rastae86
Re: Head build
Postby Rastae86 » Thu Feb 21, 2013 12:03 am
Werd . Theshaw just got his dreams crushed lol
runkillerrabbit
Re: Head build
Postby runkillerrabbit » Thu Feb 21, 2013 12:29 am
i think that formual atlantic engine for sale $15k
can rev 10 all day?
viewtopic.php?f=16&t=2245
this and this
viewtopic.php?f=16&t=1767
FIDM fashion design
ITT tech electrical engineer
R2D2 build log
