OEM Upgrade Horn for AE86?
cincybranr
Postby cincybranr » Thu Oct 01, 2020 6:56 am
Hey everyone,
I noticed on some MR2 forums that people have successfully swapped (plug n’ play) louder RX300 horns. I know I can do hella etc but wanted a louder oem horn.
Any thoughts or suggestions.
Thanks everyone!
Progress. Not perfection.
Nick94tt
Re: OEM Upgrade Horn for AE86?
Postby Nick94tt » Thu Oct 01, 2020 2:59 pm
Not a bad idea. Could probably pull up part photos on rockauto/toyota parts dealers and compare the connectors. Or take your current horn to a junkyard to mix and match.
Worst case just solder/heat shrink the new connector onto your harness. I'd expect something like a tundra would have a substantially louder horn. Just have to match the polarity.
(Anything recent, honestly)
Postby jondee86 » Thu Oct 01, 2020 4:34 pm
Pretty sure I used one of these...
https://www.pflcgab.com/index.php?main_ ... s_id=15893
It was one half of a two-tone set. The guy who bought the set only used one
and I grabbed the other one. Was a big upgrade in sound and tone compared
to the OEM squeaker :) Didn't need to upgrade the factory wiring or fit a relay
either which made it a straight forward install. Can't remember if I had to
change the terminations, but easy job anyway.
allencr
Postby allencr » Thu Oct 01, 2020 6:26 pm
All the above.
Yours might only need some tuning.
clean its terminals, clean ground if it's 1-wire, clean its relay terminals & contacts, adjust it.
That adjustment screw on it, self tapping or threaded& locknut, will change it quite a bit until there's no sound at all at either end of its range.
Playing with & setting it for the best continuous sound probably isn't going to be close enough to the setting it needs to work well when cold.
good luck
cincybranr
Postby cincybranr » Fri Oct 02, 2020 7:08 am
Appreciate all of the information and support! Thanks everyone.
Nick94tt
Postby Nick94tt » Sat Oct 03, 2020 1:28 pm
Completely forgot. Back in the day I had a mk2 MR2. Got bumped in the front just hard enough to dent the horn. Sounded like the dying giraffe in the south park movie. I miss that horn. >_> (car, too. :lol: )
cincybranr
Postby cincybranr » Mon Oct 05, 2020 10:17 am
Nick94tt wrote:Completely forgot. Back in the day I had a mk2 MR2. Got bumped in the front just hard enough to dent the horn. Sounded like the dying giraffe in the south park movie. I miss that horn. >_> (car, too. :lol: )
Epic!! :lol: :lol:
