Windshield washer question usdm ae86
Posted: Sun Oct 04, 2020 12:50 am
Hoping someone can help. My wipers work, but my washer
doesn’t. I disconnected the washer motor to check continuity of the harness to the switch but no luck. Nothing when engaging the switch. I then removed the switch and checked continuity from harness to motor.. no luck. All contacts looked pretty clean so I’m thinkin maybe a break in the circuit. Also noticed I have zenki dash/engine harness with Kouki wiper motor. Not sure if that matters though. I also tried to install a spare switch just to see but washer still didn’t work.
Side note. When you push the washer button does it trigger wipers and washer simultaneously?
