Rear end bearings and coil igniter part #s
YoShImUrA
Postby YoShImUrA » Fri Feb 22, 2013 3:01 pm
Hi everyone,
I'm gathering up the bearings and other parts needed to re-do my GT-S Kouki rear axle.
Also looking to have a spare igniter as it seems many are having issues with them lately.
So far I got these references (all is one part unless specified):
    90368-41050 BEARING, TAPERED ROL (2 units)
    90366-34019 BEARING, TAPERED ROL
    90368-30002 BEARING, TAPERED ROL
    90179-18001 NUT
    41231-22010 SPACER, DIFF DRIVE P (2 units)
    90311-38015 SEAL, TYPE T OIL
    04421-14010 BEARING,BAL,35,72 K
I believe I'm just missing the outer bearings which you can get for $110-119 from some shops here at the classifieds, but I was wondering how much of a difference it is to get it all from toyotapartszone.com
And of course, the coil igniter part #.
Thanks in advance!!
ga_goosh
Re: Rear end bearings and coil igniter part #s
Postby ga_goosh » Sat Feb 23, 2013 1:13 pm
I got everything i needed from http://www.weirperformance.com for 154. it was a little more expensive since i opted for the solid pinion spacer which is supposed to help the rebuild last longer. you can use a oem crush sleeve tho if you would rather save some money.
the igniter p# is:
89620 IGNITER ASSY
89620‑12290 DENSO 1 $500.58
89620‑12310 TOSHIBA 1 $508.17
http://www.toyodiy.com/parts/p_U_1986_TOYOTA_COROLLA_AE86L-ECMQFA_8401.html?hl=89620
I <3 my AE86
4AG Manual
AE86 FSM
YoShImUrA
Postby YoShImUrA » Sun Feb 24, 2013 1:25 pm
Thank you, that was some interesting info, although I was trying to get it all "Toyota". If anybody can provide those numbers, I'd be very grateful!
As for the igniter, I have tried to put in those references and neither worked... :?
ga_goosh
Postby ga_goosh » Sun Feb 24, 2013 1:58 pm
did you click the link? the link is to toyodiy for the ignitor
my car came with a denso so straight from my igniter: 89620-12290
I <3 my AE86
4AG Manual
AE86 FSM
YoShImUrA
Postby YoShImUrA » Tue Feb 26, 2013 12:20 am
Yeah, I did try with the part #s on your link, which are the same and neither showed up in the website I mentioned in the first post.
As for the references in your igniter, only the ASSY shows up, but it's discontinued =(
Thanks again for your help though. I'll ask a buddy of mine that works at Toyota parts and let you guys know what I find out!
