Are there any “low profile” wheel bearing dust caps?
yabaiani
Postby yabaiani » Mon Mar 27, 2023 10:12 am
I’m trying to fit some center caps on the front wheels but the dust caps protrude a lot so not sure if there is an alternative. Let me know!
sirdeuce
Re: Are there any “low profile” wheel bearing dust caps?
Postby sirdeuce » Mon Mar 27, 2023 1:40 pm
If you're going to cover them you could consider flatening the dust cap with a hammer. Not sure how far you can get with that, most axles protrude far enough that the cap doesn't leave much room under the cap. Pull a cap and check your axle length to see where you can go with it.
One shot, one kill.
Postby jondee86 » Wed Mar 29, 2023 10:04 pm
If you only need a few millimetres more to allow you to fit your low profile centre caps,
you could maybe get there with some slip-on wheel spacers. You may need to get some
longer wheel studs if you go that route.
