Zenki Sr5 to zenki gts swap. What do i keep from the 4ac ?
Posted: Wed Mar 19, 2025 12:24 am
by David4age
So far i kept the full ac line , charcoal canister
Anything else i need to keep ? Front light harness is being switch over to zenki gts.
Re: Zenki Sr5 to zenki gts swap. What do i keep from the 4ac ?
Posted: Thu Apr 17, 2025 8:44 am
by El Gato Felix
I would swap everything out, that's what I did. Surprisingly I had fun doing it. Also make sure you fix or clean up the areas while you're doing it. If you have all the parts, then swap all the parts. In my opinion, if you take short cuts you might end up with a "No Start" or some of your electrical comments might not work.
