4age 16v car keeps trying to start without key
Posted: Sun Apr 06, 2025 7:57 am
So I'm dealing with an issue where I fire the car on then it keeps trying to turn over after i've let go of the key.
It will sometimes fire up but be really weak like its running on only a few cylinders. If i remove the key it will stay on in that firing sequence. The only way to get it to stop is to cut off the fuel or disconnect the battery. I assumed it was possibly the ignition switch and ignition cylinder being old and weak. Though, after replacing those, the issue remains. Any ideas boys?
