SR5 swap help me!
Posted: Wed Mar 13, 2013 10:48 am
by EASTSIDESD
Thia is my first project and I wanted to do it right I bought an sr5 with blown engine and then I bought a 4age head with a 7afe block wanted to know what else I need to complete this swap so far this is what i know i need Oil pump ,water pump ,oil pan ,944 horse timing belt, t3cam gears ,rwd full intake manifold ,fuel pump ,full gasket set ,ecu ,gts wiring harness is there anything else ii need ? Please help me for I am I noob !
Re: SR5 swap help me!
Posted: Wed Mar 13, 2013 10:55 am
by MisterJerk
the only thing i can think of is this:
you can get this back issue. One of the best DIY/how to's i have seen yet. covers everything including setting up a diff.
Posted: Wed Mar 13, 2013 11:24 am
by EASTSIDESD
MisterJerk wrote:the only thing i can think of is this:
Thanks misterjerk for the response do you know where I can purchase that issue? And mainly im just wondering what other parts I need if I missed anything but I think ima take it to a shop for them to do I dont have a garage or anything so its hard for me to work on my car on the street
Posted: Wed Mar 13, 2013 4:53 pm
by gotzoom?
You also want the next issue of the magazine. It has the rest of the swap procedure.
Posted: Wed Mar 13, 2013 6:34 pm
by Grant
Posted: Thu Mar 14, 2013 5:25 am
by MisterJerk
Issues #15 and 16 are the ones.
you can try emailing them at their website
http://www.projectcarmag.com/or WTB ad in the classifieds.
its not recommended by the state of California and may be known to cause cancer, but if you are internet savvy you might be able to find it in .pdf format.(if you dont know what that is, you are NOT internet savvy)
Posted: Fri Mar 15, 2013 11:37 pm
by Tora
Kindof a rough project for a first-timer... I'd rebuild that 4AC and upgrade the carbs / motor mounts / power steering to manual steering swap and hook up an electric fan. I just did a 4AGE rebuild as my first major project, and the idea of a swap is still a bit daunting.
Posted: Sat Mar 16, 2013 5:57 pm
by MiLLz
you also need the front half of the GTS transmission, air flow meter, air hose, GTS fuel lines, fuel rail, TVIS butterfly plate, fuel injectors, baffled GTS gas tank, GTS fly wheel, flex plate..... list goes on.
edit: distributor, cap/ rotor / wires/ ignitor
Posted: Sat Mar 16, 2013 7:56 pm
by mikeyee
physical copies have been sold out of the proj mag sr5-gts swap.
you can find scans here:
http://www.ae86drivingclub.com.au/forum ... -Taka-Aonobut the diy swaps that andrew assassin100000000 wrote are also just as good (if not better)
Posted: Sun Mar 17, 2013 1:04 am
by emagen303
pm me or email me
matt.zebracki@yahoo.com, i just finished my swap and most the **** people list you dont need. working on a thread as we speak.
Posted: Mon Mar 18, 2013 3:25 am
by rc.square24
You will save a lot of time / money and headache (shop hours too) if you can find a donor gts that you can just give them to swap the stuff over. At the very least most of the stuff up to and including whats mounted on the firewall (pedals, dash harness etc etc). Rear axle and prop shaft will depend on what you want and have on your current SR5.
Posted: Mon Mar 18, 2013 11:11 pm
by overspool
Here is a "bare minimum" list of everything "necessary" to get an SR5 running with a GTS swap:
Longblock
Wiring Harness (underdash and engine harness, including fuse boxes)
All accessories for the engine (fuel rail, injectors, oxygen sensor, AFM, etc)
ECU
GTS transmission bellhousing
GTS clutch line (I used a long stainless steel braided line and ran it from the clutch master cylinder to the slave cylinder)
GTS clutch slave cylinder
in line fuel pump and fuel filter
that's it as far as I can remember.
I got rid of the charcoal canister and all emissions systems, used an in line fuel filter and an in line fuel pump (walbro 190lph will do more than enough),wired the fuel pump to a switch with an inline fuse, and swapped the fuel vapor line (for the charcoal canister) and the fuel return line, and kept teh SR5 gas tank. Works like a charm. No problems yet, granted I've only been able to put a little over 100 miles on the car since the swap, but I'm confident in my work.
Posted: Thu Mar 21, 2013 12:38 pm
by emagen303
i just finished my swap like 3 weeks ago.
wiring harness, all of it. +ecu to match(i know you can modify sr5 but this is just easier)
when i swapped my 92 motor i had to use the injectors and rail off of a 85 mr2 to match the harness clips.
had to re route the water lines
need older water temp sensor clips to match harness plugs.
used the maf from the 92
used the dizzy from the 85 mr2 to match plugs.
coil/igniter from 85 mr2
pilot bearing for tranny shaft
dont need a gts bell, slave or line. Just need a steel braided and route to away from the exhaust.
i used my stock fuel lines. no issues just need a inline pump
dont need gas tank
if you switch to gts rear end and use sr5 bellhousing you can still use the same drive shaft
if you use gts rear and gts bellhousing you will need a gts driveshaft.
Posted: Tue Mar 26, 2013 12:06 am
by EASTSIDESD
I appreciate all the input guys
