Got my first ae86!
socal1jzsupra
Got my first ae86!
Postby socal1jzsupra » Fri Mar 15, 2013 11:27 pm
ok guys just a week ago i bought myself a 85 toyota corolla gts! and im already looking for parts to buy for it, i been searching on bride, sparco, etc seats, i was just wondering will any of those seats fit the corolla? i know as long as i get the right sliders i should be fine... but just wondering is there any specific seats that wont fit the corolla? thank you.
Re: Got my first ae86!
Postby Deuce Cam » Fri Mar 15, 2013 11:53 pm
Wider than average fixed back bucket seats can be tricky to fit with the base rail setups that are available and sometimes require fabrication to make it work. Any seats wider than roughly 15.5-16" at the base will be tougher to fit low down.
Reclining buckets are a different story though. I haven't tried any aftermarket ones in an ae86.
LongGrain
Postby LongGrain » Sat Mar 16, 2013 12:41 am
most bride seats will fit fine in corolla. I had NAMS rails and fit a vios III just fine as well as a Zeta II. However my Tom's carbon SPG replica would not fit my rials. I had to mount them to the floor wider than the stock position.
EJ86
Postby EJ86 » Sat Mar 16, 2013 1:43 am
I have Sparco speed seats on my GTS:
Parts used:
-Sparco Speed seats
-Momo seat base brackets
-Sparco sliders
-Sparco/Sabelt 3pt harnesses
socal1jzsupra
Postby socal1jzsupra » Sun Mar 17, 2013 12:20 am
wow clean seats there ej86... ya i just wanna buy something that will bolt up perfectly and dont have any issues with it at all. ima gut out the corolla and repaint the whole inside and just set a couple of nice seats in there...
socal1jzsupra
Postby socal1jzsupra » Sun Mar 17, 2013 12:22 am
ej86 are those seats comfortable? they are not reclining seats so i just wonder how you feel bout just sitting up straight all the time?
socal1jzsupra
Postby socal1jzsupra » Sun Mar 17, 2013 11:45 pm
just wondering im pretty chubby guy, not really big but do XL seats fit in an ae86?
LongGrain
Postby LongGrain » Mon Mar 18, 2013 5:12 am
not really unless you make custom rails. Like I said my SPG style bucket (up to 34" waist comfortably) did not fit between my nams rails, I had to mount them wider and weld them to the floor.
this is assuming you're talking about side mount seats, if you are referring to bottom mount, that's a whole different story.
Red
Postby Red » Mon Mar 18, 2013 10:22 am
"ya i just wanna buy something that will bolt up perfectly"
Well...you might have bought the wrong car. There's very little that fits these cars, at all, for anything. Except a Double-DIN stock radio size.
Even when someone says something will fit, make sure they are sure this is for the RWD Corolla, not the FWD Corolla (FX-16) that shipped in the same years. And that it is for your GT-S, not the diesel (!) or the base model Corollas, because even when these cars were new, damned little fit into them and most folks, including the dealers, couldn't figure out what car it was. I used to bring my own printouts for front-end alignments because Hunter had the FWD version programmed into their equipment and the techs couldn't find my car.
"GT-S, oh, you mean Celica?" That's right, that was the 1980's. Everyone knew a GT-S was a Celica, outsold these at least twenty to one, probably fifty to one.
-- Original owner, 1985 GT-S
SolidSTI
Postby SolidSTI » Mon Mar 18, 2013 10:30 am
I run a Bride DIGO II and a bride rail made for the AE86. Fits perfectly.
1985 Corolla GT-S | 1985 Trueno Sprinter | 1989 Skyline GT-R | 2001 Prelude | 2005 STi | 2008 Forester XT| 1991 M923A1
http://TruFactsRacing.com
Postby Deuce Cam » Mon Mar 18, 2013 11:17 am
I went through the same thing as LongGrain...
NAMS rails with Recaro pole position didn't work without binding (seat was 17" wide i.e. too wide). I managed to get it all bolted in, but found out later the binding caused a small tear on the floor around one of the welded nuts for the seat base :(. I ended up cutting/welding the seat based to properly accomodate the seat and fixed the floor.
The side mount bucket seat base rails that are available only accommodate seats 15-15.5" wide without binding. I'm currently using NAMS rails with the Recaro Profi SPG bucket and everything bolts up fine without modification. It's also at least 2" lower the stock seat in its lowest position. Anyone over a 34" waist is going to have a hard time fitting in seats this size.
Red
Postby Red » Mon Mar 18, 2013 11:32 am
"It's also at least 2" lower the stock seat"
Oh hell, just slap some velcro on my butt and stick me to the carpet.<G>
Postby Deuce Cam » Mon Mar 18, 2013 11:41 am
Haha I'm 6'3" so every bit helps. Even I can't see over the dash sitting on the floor, I've tried.... :lol:
Red
Postby Red » Mon Mar 18, 2013 11:47 am
Six foot three? Oh, you must have the car with the Gurney Bump in the roof. Been meaning to get one of those myself, because all I need is good posture to hit the roof, and I'm no six three. (Dan Gurney had a bump installed in the roof when he was racing the Ford GTs, it was the only way to fit him in the car.)
socal1jzsupra
Postby socal1jzsupra » Tue Mar 19, 2013 1:07 am
ya im thinking this seat and hardware are side mounted...
http://thmotorsports.com/store/account/ ... mid=149854
will this work out for the ae86?
