Sr5 5 speed swap speedometer cable?
rumsawatti
Postby rumsawatti » Fri Mar 22, 2013 7:09 pm
Is there a difference between the sr5 speedo cable in the auto and manual? Will I need a manual one to swap my automatic?
Also, will i need anything else for the swap? I have as follows:
T50 Transmission with bellhousing and fork
Clutch assembly
Flywheel
Starter
Shifter
Driveshaft
Clutch and brake pedal assembly
Clutch master
Clutch slave
Clutch slave hardline
Clutch hydraulic hose
Anything else? be it small or big, I would like to have everything together so that I dont have to make part runs in the middle of the swap. Also, do I need different bolts for the manual bellhousing, flywheel, etc or will the bolts from the auto work fine?
rumsawatti
Re: Sr5 5 speed swap speedometer cable?
Postby rumsawatti » Sat Mar 23, 2013 7:15 pm
anyone??
rumsawatti
Postby rumsawatti » Sun Mar 24, 2013 11:41 am
What do you mean? I am doing ar5 automatic to sr5 5 speed swap. Im not swapping in gts.
rumsawatti
Postby rumsawatti » Mon Mar 25, 2013 6:49 am
all good, Thanks for the input! :)
