Whinning noise when braking
Posted: Tue Mar 26, 2013 8:47 pm
by miswuevos
Could this be a bad caliper?
I've checked for any leaks on the hoses, and they seem fine
It has a new brake booster
I checked my pads, and they are pretty messed up from one side...will update pics later
It sounds exactly the same as when a truck usually brakes and makes that long a$$ whinning noise. But this is only when braking slow
Re: Whinning noise when braking
Posted: Tue Mar 26, 2013 10:45 pm
by EJ86
Check your anti-rattling clips on the calipers...
Posted: Wed Mar 27, 2013 9:51 am
by miswuevos
EJ86 wrote:Check your anti-rattling clips on the calipers...
I did, still makes the same dumb sound...someone told me that it is wheel bearing? but if it were the wheel bearing then it should sound very differently?
Posted: Wed Mar 27, 2013 10:29 am
by allencr
No, bearings never whine when braking.
What does 'pretty messed up from one side' mean"
One pad worn more then the other because of a sticky piston or slide, or left to right side of the car?
Brake pad noise, try the goop that parts places sell, taper the pad, clean & smooth the pads backing plate where it contacts the caliper & those clips, piece of gasket paper/shoe box between the piston & pad.
Posted: Wed Mar 27, 2013 12:13 pm
by miswuevos
allencr wrote:No, bearings never whine when braking.
Here is the brake pads..
Posted: Wed Mar 27, 2013 10:27 pm
by KonaTrueno723
I'd try putting a taper on the leading & trailing edge of those pads & see if that helps. Are you runnin drilled/slotted rotors miswuevos?
Posted: Thu Mar 28, 2013 6:04 am
by MisterJerk
is the bottom one worn unevenly? looks like it, i bet the caliper slider thing is bent or frozen. when changing your brake pads, its a good idea to lube the bolts and stuff that allow the caliper to slide on the carrier.
Posted: Thu Mar 28, 2013 8:07 am
by miswuevos
KonaTrueno723 wrote:I'd try putting a taper on the leading & trailing edge of those pads & see if that helps. Are you runnin drilled/slotted rotors miswuevos?
konaTrueno723. No I am running solid discs
MisterJerk. I resent the calipers back to the company and told them they were defect, gladly they responded and told me it is going to take a week and half
. I guess its worth the try,
I have tried lubing the bolts, put the shims, the clips, and nothing...
Will get back to you guys when I get them back
Posted: Thu Mar 28, 2013 8:31 am
by allencr
USE THEM!!!!
Get them stinking hot, then come back & whine about it!
