offset help
EASTSIDESD
offset help
I have a 1985 sr5 I dont know what to look for I know it is 4x114.3 but I thought it was a 0 offset but wikepedia said its -33? Also was wondering what wheel size is best for function I was gonna go with 15x8 pictures will be great thank you!
Re: offset help
I cant give you a deffinate size as many people like different sizes but i can help you to understand offset. the offset is the measurement of the mounting surface from the center of the barel. back spacing is the distance from the mounting surface to the back of the wheel. so if you measure the back spacing and you know the rim width you can get the offset from this chart.
also you can use this tire and wheel calc to play around with different offsets. and compare them to stock or another known size
http://www.rimsntires.com/specs.jsp?item=Wheel-Tire%20size%20comparer
