AE86 Engine Ground Diagram?
cliqwe
Postby cliqwe » Wed Apr 03, 2013 9:35 pm
Is there a diagram for where the grounding points are in the the engine bay and on the tranny? I took mine apart and cant remember where they go D:
HASport AE86
Re: AE86 Engine Ground Diagram?
Postby HASport AE86 » Thu Apr 04, 2013 11:24 am
Doesn't really matter where on the trans, you can use one of the rubber mount bolts or the clutch slave bolts.
You should have:
Engine block to driver frame rail
Cylinder head to firewall
Trans to firewall or bottom chassis
cliqwe
Postby cliqwe » Thu Apr 04, 2013 12:34 pm
Oh hey thanks man, always being so helpful ;D
HASport AE86
Postby HASport AE86 » Thu Apr 04, 2013 3:25 pm
cliqwe wrote:Oh hey thanks man, always being so helpful ;D
More fixed corollas=More driving buddies.
Red
Postby Red » Thu Apr 04, 2013 5:43 pm
"you can use one of the rubber mount bolts "
Ah, yes, as long as you don't try to connect the ground strap to the isolated "same" side of a mount.<G> You really could just wind up grounding the block to itself, instead of the tranny or body, if you didn't know the bolts don't go straight through, no?
-- Original owner, 1985 GT-S
aaronlee133
Postby aaronlee133 » Wed Feb 17, 2016 9:17 am
Question: I'm trying to from reading the above I believe this ground should attach to the tranny. The wire was 'free' when I purchased the car and would ideally like to place it where it originally belonged. Can anyone assist? Thanks -Aaron
ThunderBolt
Postby ThunderBolt » Tue Sep 17, 2019 9:38 pm
Ground strap to transmission bellhousing.
