Brake booster delete
Billy_Andrea
Postby Billy_Andrea » Tue Apr 09, 2013 10:02 pm
Does anyone have any good links or info on a brake booster delete such as parts used etc... ?
mikeyee
Re: Brake booster delete
Postby mikeyee » Tue Apr 09, 2013 10:54 pm
performance options has some made iirc.
http://performanceoptions.net/products.html
Billy_Andrea
Postby Billy_Andrea » Tue Apr 09, 2013 11:11 pm
Thanks Mike. You don't know if they use an S13/14 master, do you ?
gaijin_rokurunner
Postby gaijin_rokurunner » Wed Apr 10, 2013 5:05 am
Performance options never responds to email i can possibly get the N2 kits they sell in japan
RuizXIII
Postby RuizXIII » Wed Apr 10, 2013 12:58 pm
Never even heard of Performance Options.
It'd be nice if they listed prices on their website...
irony.cc
mikeyee
Postby mikeyee » Thu Apr 11, 2013 1:24 am
RuizXIII wrote:Never even heard of Performance Options.
just give 'em a call!
they're good people.
Billy_Andrea wrote:Thanks Mike. You don't know if they use an S13/14 master, do you ?
hmm, not sure? I do know that's what Yusuke-san from CarPeace did with his hatch. He runs a brake booster delete with an s-chassis BMC, and no proportioning valve (iirc, the s-chassis BMC has one internally?)
http://www.speedhunters.com/2011/10/car ... eace_ae86/
CBY Japan also has them available.
http://ameblo.jp/cby86/entry-11159769857.html
I think.. couldn't find it in the CBY store though...
ga_goosh
Postby ga_goosh » Thu Apr 11, 2013 7:06 am
billy, the ae86 and the schassis bmc mounts are the same so you can use either or. you could use the r33/z32 1" master as well
I <3 my AE86
4AG Manual
AE86 FSM
Jacare
Postby Jacare » Thu Apr 11, 2013 8:36 am
Any pros or cons of deleting it other than freeing up space?
I'm having the worst time with my booster leaking everywhere.
mikeyee
Postby mikeyee » Thu Apr 11, 2013 1:32 pm
Jacare wrote:Any pros or cons of deleting it other than freeing up space?
mostly just preference. some dudes like the real hard feel of the brake pedal without the booster.
Jacare
Postby Jacare » Thu Apr 11, 2013 3:32 pm
nothing with smogthough right? stupid question
sqznby
Postby sqznby » Thu Apr 11, 2013 5:38 pm
Have you ever driven in a car without a booster to get to feel the difference between the two?
I'm with Jacare, not only would it clear out some much needed space but it would help my leaky booster to.
Thanks
Postby Deuce Cam » Thu Apr 11, 2013 6:21 pm
It's a bad idea imo for a street car, especially when using a stock size or larger bmc. It will decrease braking performance and feel, arguably dangerous. I've read that some people use the stock bmc and relocate the mounting point up slightly for added leverage, but yeah...
If you do a custom setup with smaller than oem bmc, or perhaps a dual master setup with a brake balance bar it will be usable, but the pedal will still be really hard.
mikeyee
Postby mikeyee » Thu Apr 11, 2013 7:22 pm
sqznby wrote:Have you ever driven in a car without a booster to get to feel the difference between the two?
Thanks
yeah, it's not really fun...
you can take off the vacuum line to the booster from the intake and cap the lines, and try it out like that.
RuizXIII
Postby RuizXIII » Thu Apr 11, 2013 9:03 pm
That CarPeace engine bay is probably one of my top favorites.
I love all the work they did in there.
I hear so many mixed things about deleting the brake booster.
I guess it would take some getting used to (?)
irony.cc
T.C
Postby T.C » Sun Apr 14, 2013 6:40 am
Ive had my brake booster disconnected for awhile now and dont think i want to put it back on. I actually like the pedal feel. Takes some getting used to though
petersbity
Google is devil
Postby petersbity » Sun Jul 10, 2016 6:27 am
Google chrome logo 666
Postby jondee86 » Sun Jul 10, 2016 2:31 pm
Wrong forum bro... you want.... http://www.bibleprophecytruth.com/topics/satan
davew7
Postby davew7 » Mon Jul 11, 2016 6:04 am
If you remove the booster you really need to change the brake pedal lever ratio. The stock pedal ratio is about 3.8 to 1 [boosted]. You need to relocate the master cylinder up slightly and drill a new hole for the push rod that will give you a lever ratio of 5 to 1. You will be much happier with the pedal feel. If you take the canister apart you can use the internal rod with your manual brake system. The canister is spring loaded so clamp the halfs together before separating. You will also have to remove the small push button cap on the end of the internal rod. But once removed the radius is the correct size to fit in the stock AE86 master cylinder. Dave W
Nomnom83
Postby Nomnom83 » Sat Jul 16, 2016 5:01 pm
Been thinking about doing this, during my last track day it rain a bit and the brakes locked up easier and I wasn't able to get a good feedback from them as in the dry. I've read that the ae86 is light enough to not need a booster and taking it out lets to brake at the limit easier. This is FC brakes with a 1" master and wilwood porportioning valve.
ryanjayx
Postby ryanjayx » Fri Aug 05, 2016 9:34 pm
Old thread, but I did this in my STI, and have no problems. Switched to a Tilton master, and a Wilwood proportioning valve, located in my wiper cowl.
