need help with rear shocks
RenKAZUKI
Postby RenKAZUKI » Thu Apr 18, 2013 11:05 pm
so im planning on putting new shocks on my car, I heard that a lot of people uses the one from camaro. I was wondering what year camaro or whats the part number of either tokico or kyb. thanks in advance for the help.
Red
Re: need help with rear shocks
Postby Red » Sat Apr 20, 2013 1:57 pm
If you are thinking about KYB, why not buy the KYB shocks for the car? Ride is pretty much oem-ish, rear shocks are dirt cheap if they are still in production.
-- Original owner, 1985 GT-S
carbd7age
Postby carbd7age » Sat Apr 20, 2013 5:21 pm
2001ish Camaro.
Knockoff Crew member #0001
RenKAZUKI
Postby RenKAZUKI » Tue Apr 30, 2013 9:14 pm
carbd7age wrote:2001ish Camaro.
thank you very much.
EJ86
Postby EJ86 » Wed May 01, 2013 12:08 am
Hoy pare:
82-93 Camaro
KYB (non-adjustable): PN: 343211
I gotta do mine too...
Red
Postby Red » Wed May 01, 2013 5:47 am
You guys using Camaro parts on a modified suspension? Or did KYB stop making the stock shocks?
EJ86
Postby EJ86 » Wed May 01, 2013 6:38 am
Red wrote:You guys using Camaro parts on a modified suspension? Or did KYB stop making the stock shocks?
Modified suspension: Short Stroke conversion SW20 front shocks and Camaro rear shocks.
ga_goosh
Postby ga_goosh » Thu May 02, 2013 5:09 am
Iv heard that it is better to use the sw20 rear strut inserts in the front of our corollas since most of the weight is in the rear of an mr2
I <3 my AE86
4AG Manual
AE86 FSM
carbd7age
Postby carbd7age » Thu May 02, 2013 8:03 am
Yep. Rides like a log truck on the highway but she grabs them corners.
Cavi Mike
Postby Cavi Mike » Thu May 02, 2013 7:05 pm
Once upon a time...
This topic was brought up about how well the Camaro shocks actually work for this application. Someone who worked for KYB said the Camaro shocks aren't valved properly - they just happen to bolt right in. They said the Fox-body Mustang shocks are actually better but they need different lower bushings to bolt in. I bought a pair years ago but never put them in, they're still in my back seat, so I can't comment on the actual performance.
I just want to bring this up in case anyone was actually looking for better performance - not just cheap short stroke shocks.
pearls ain't free
mikeyee
Postby mikeyee » Thu May 02, 2013 7:21 pm
also have heard ford f150 front shocks will work as rears for our cororras. and are a shorter stroke/height than the maro's
carbd7age
Postby carbd7age » Fri May 03, 2013 5:01 am
Damn might as well run a solid bar instead of a shock if you're gonna run front F one fiddy's!
Postby Deuce Cam » Fri May 03, 2013 9:25 am
Whatever works I guess. In theory it sounds like a terrible idea because those cars are all a lot heavier than a corolla. I suspect an over damped setup would be ok for drifting? As ga_goosh mentioned, the opposite can be said for using sw20 fronts on the front of a corolla (i.e. in theory they should be under damped). Real world practice is a different story though.
Unfortunately it doesn't seem like there are any front and rear short stroke shocks valved specifically for the ae86. Word is most of the valving used for ae86 applications (e.g. hts) are just taken from other makes/models and packaged for an 86. Even the trd ss fronts people use on the 86 are meant for an ae92...
