Help identify this noise
Re: Help identify this noise
Postby totta crolla » Sun May 05, 2013 12:53 pm
Remove the alternator / water pump drive belt and try it again.
It will be ok to run for a few minutes.
wideslider
Postby wideslider » Mon May 06, 2013 5:21 pm
^sounds likely. If that doesn't work take the cam gear cover off to see the timing belt isn't doing something weird and is rubbing on something.
