The 4AC canundrum, a short story written by me.
Posted: Tue May 21, 2013 9:25 pm
As I'm staring at my fridge on a windy Tuesday evening, wallowing in self pitty. I trully wonder if by some odd series of fate I ended up with a demon of a corolla, two major issues are resting heavily on my mind. The first, I can't decide whether to make a whisky and coke, or opt for a simple yet delicious Blue Moon. The second is why after so many attempts I can't get my Corolla to run. A few moments pass by and I reluctantly reach for the beer. After popping the top I start to think about the events of the past couple months.
About 2 months ago the head gasket blew in the corolla. After parking it I started the tear down and sent the head off to the machine shop. I ordered the gasket, grabbed some oil, a filter, head bolts, and the coolant required for the rebuild. While patiently waiting for my head to be finished, I spent most of my time chilling with pals, smoking shisha, and of course working my 2.5 jobs. Living the life right?
Once I got the head back from the machine shop I noticed the 4ac bolts I ordered were actually the incorrect application. Hunting down the bolts proved to be more difficult than anticipaited. So I went against my initial rule of never re-using head bolts. I inspected the entire engine and cleaned everything nice and pretty. I set timing perfectly and aligned the distributor to cylinder one multiple times. The only way I can get it to start is if i actually set it a tooth retarded, richen the carbuerator, and turn in the idle adjustment screw. And as predicted it runs sluggishly, throttle response is horrid, and diesels when turned off. I deleted egr aside from that everything is as before. My only remaining theory is maybe, just maybe, it's got bad gas and therefore acting up. If anybody has any ideas I am all ears. I just need to get it running long enough to do my fuel injection swap. I can't even get it to start today to play with timing. It just sputters, backfires, and acts like it's missing and dies. I've considered just setting it on fire.
