How to install key cylinders?
truenoboy
Postby truenoboy » Sat May 25, 2013 12:05 pm
Anybody know how the door key cylinders go in? I need to put mine back in after doing a restore of my car, but they don't seem to line up correctly with wholes.
jdm86gtz
Re: How to install key cylinders?
Postby jdm86gtz » Sun May 26, 2013 5:05 am
The barrels are sided so try them in the other doors.
Postby Deuce Cam » Sun May 26, 2013 8:37 am
^That, and line up the metal rods from the door handle/lock mechanisms to the clips on the lock cylinder and clip them in place (be careful with the plastic clips on the lock cylinder because they break easily). There's a also a metal retention clip that slides between the lock cylinder and sheet metal on the inside of the door to hold it in place.
truenoboy
Postby truenoboy » Thu May 30, 2013 8:28 pm
Thanks guys! They still don't align though. Am I supposed to bang and force them in?
Postby Deuce Cam » Thu May 30, 2013 9:02 pm
I completely gutted and re-assembled two doors last fall. Something is not right if force is needed to line up and attach the rods to the clips on the lock cylinders. They line right up and you clip them together using only your fingers. The clips are tiny and plastic. They will break if you use force.
Edit: You can try turning the lock cylinder and also adjusting the lock on the door handle to make sure they're synced. Also, maybe try lining the rods/lock cylinder clips up without the door handle/rods bolted to the door, or at least with them loosely connected to the door.
Cavi Mike
Postby Cavi Mike » Thu May 30, 2013 10:20 pm
Put them back in? As in - these are the locks that came from your car? Or are you trying to use new locks or ones from a different car?
pearls ain't free
truenoboy
Postby truenoboy » Sat Jun 08, 2013 11:12 am
These are the locks that came out of the car. I can will try again today though....for the 4th time.
