driveshaft u-joint
ae86_dreamer
driveshaft u-joint
Postby ae86_dreamer » Thu May 30, 2013 8:27 am
guys, any of you done a u joint driveshaft replace on the sr5 coupe. read from some forumsthat the ae86 driveshaft is non servicable.any ideas and suggestions? thanks in advance
ga_goosh
Re: driveshaft u-joint
Postby ga_goosh » Thu May 30, 2013 9:43 am
they are not servicable. you will have to replace the drive shaft
I <3 my AE86
4AG Manual
AE86 FSM
allencr
Postby allencr » Thu May 30, 2013 10:49 am
Take it to any driveshaft shop & Look on youtube for u-joint fixes.
The staked joints that don't have a circlip groove in the yoke, use a joint with cups that have a groove.
Jeonsah
Postby Jeonsah » Sat Jun 01, 2013 4:02 pm
They ARE replaceable.. I have taken my GTS driveshaft to a driveshaft shop and they replaced the ujoints with new ones that have a fitting so you can greese them up. So yeah, just take em to a shop and have them tell you whether or not they can do them.
ae86_dreamer
Postby ae86_dreamer » Sun Jun 02, 2013 12:11 am
alright! the thought of replacing the whole driveshaft is not a option right now! coz i hear a thump noise everytime i shift gears specially on 2nd to third gear. i read on some forums that the u joints might be at fault. atleast now i have an idea that i can be replaced. thanks,guys!
Jeonsah
Postby Jeonsah » Sun Jun 02, 2013 9:18 am
You can inspect the ujoints when the driveshaft is off the car. You should grab the ujoint and try to move it in all directions. It should be tight with no slop and it should move slowly. If it has slop, it will be really loose and move fast. You can hear it smacking etc when you move it. Here is a vid on how to check the ujoints:
http://www.youtube.com/watch?v=dlnAbshguZI
KonaTrueno723
Postby KonaTrueno723 » Sun Jun 23, 2013 11:13 pm
Jeonsah wrote:They ARE replaceable.. I have taken my GTS driveshaft to a driveshaft shop and they replaced the ujoints with new ones that have a fitting so you can greese them up. So yeah, just take em to a shop and have them tell you whether or not they can do them.
Jeonsah=by any chance,do you happen to know the part# for this replacement u joint? The info will be great for me as well as for many others who could encounter this DS prob in the unforeseen future.. :D
87 GTS Coupe
72 Blown 6-71 Pro Street Vega
