Please Delete
Posted: Sun Jun 30, 2013 6:06 pm
by TheOxyMorin
Hey all,
I purchased a Blacktop 20v for my AE86 hatch a few months ago. I have a distributor relocation kit and water cooling kit for it...
But the thing on my mind as my biggest concern now is the wiring. I have all the wiring for the car as well as the 20v wiring harness and ECU.
What am I looking at as my biggest speed bump in my build at this point?
Any advice or information would be greatly appreciated.
Thank you for your time!
Re: Need AE86 20v Swap Wiring Harness Info
Posted: Mon Jul 01, 2013 3:14 pm
by stalk86
Tweak'd Performance will make you a new one for $500
http://www.tweakdperformance.com/index2.htmlOr you can make your own following Morgan's write up or others.
http://forums.club4ag.com/zerothread?id=101899
Posted: Tue Jul 02, 2013 9:28 am
by morgan
everything is a speed bumb without the proper research prior to starting. my write-up that stalk provided will help, but theres a lot left for you to figure out.
Posted: Thu Jul 04, 2013 3:24 pm
by TheOxyMorin
I'm competent in reading and repairing wiring harnesses, connectors, etc... $500 dollars for what? I'm running the distributor and stock ECU... is there really much more I need? NO COP or aftermarket ECU...
Posted: Thu Jul 04, 2013 3:27 pm
by TheOxyMorin
morgan wrote:everything is a speed bumb without the proper research prior to starting. my write-up that stalk provided will help, but theres a lot left for you to figure out.
My engine is in good running condition fresh from Japan... I read a lot on your write-up to prepare myself. Running SQ Engineering parts for ignition and cooling but I'm not sure what else I have to do to either the 16v or 20v harnesses before they're ready to be dropped in. Thanks for you write-up btw much appreciated.
Posted: Sat Jul 06, 2013 10:09 am
by morgan
You need to merge the 2. I've done 2 like that for friends, it takes some time, not as easy as you would hope. If you're good with wiring and diagrams you should be able to figure it out with my write-up
Posted: Sat Aug 31, 2013 9:12 pm
by TheOxyMorin
morgan wrote:You need to merge the 2. I've done 2 like that for friends, it takes some time, not as easy as you would hope. If you're good with wiring and diagrams you should be able to figure it out with my write-up
I understand to a degree... but the write-ups don't explain to a degree before they start showing tons of photos. For example: What do I actually have to wire myself... it's frustrating.
