Wheel fitment
Mr.Fujiwara
Wheel fitment
Postby Mr.Fujiwara » Sat Jul 27, 2013 10:28 am
Hey guys
i know this has probably been asked a million times
but...
i got some wheels that are 15x8
and i have 20mm spacers my car is only dropped about
an inch
i was going to put nrcas on the front and take off the front wheel
spacers and leave the back ones to be even and i wanted to know if
205/50 or 55/ r15 would fit or even some 195/55/r15
if anyone has some pics that would be cool i dont really want to roll my
fenders but if needed i would do a slight pull thanks Club4ag!!
Old username: Charskiezz
20V BT: Traded For F20c Swap
gotzoom?
Re: Wheel fitment
Postby gotzoom? » Mon Jul 29, 2013 8:49 am
Take the springs out, disconnect the swaybar, install the rims and compress the suspension to see if anything hits. Anything short of doing that won't answer your question.
colingchambers93
Re: Wheel fitment
Postby colingchambers93 » Tue Jul 30, 2013 7:14 pm
i have 15x8 0 offset wheels. car is lowered dont know exactly how much. i have a manual rack and t3 nrca's. i have 195/50/15 tires and my tires rub both on the sideskirt and the inner wheel well. ive heard that all i need is a bit smaller tires and tension rods. when you lower a corolla the lower control arm moves toward the back of the car. pushing the wheel closer to the wheel well. if you get tension rods and give it some caster, it should push it far enough away from the wheel well to not hit.
Mr.Fujiwara
Re: Wheel fitment
Postby Mr.Fujiwara » Sat Aug 17, 2013 9:45 am
okay cool man thanks for the info
i had them test ftted and i may just need to tuck the fender a ittle bit
colingchambers93
Re: Wheel fitment
Postby colingchambers93 » Mon Aug 19, 2013 1:12 am
if i get those parts soon ill let you know how the rubbing issue plays out
