Manual rack problems
Posted: Fri Jan 11, 2013 12:49 pm
by Yatch
I recently got all the parts for the manual rack swap but ran into a problem with the rack itself. I turn it all the way left and it feels like it loses grip on the teeth in the rack. I have to tap the rod back in a lil bit then it catches again and I can turn right.
Any help would be appriciated thanks.
Re: Manual rack problems
Posted: Fri Jan 11, 2013 4:10 pm
by hachiroku ae86
if you turn it off the car it will do that when on the car it will stop before that point
Posted: Fri Jan 11, 2013 8:10 pm
by Yatch
Oh ok thank you I thought I had a problem with the rack itself.
Thanks again
Posted: Tue Jan 15, 2013 11:04 am
by Deuce Cam
Are the inner tie rods installed on the rack when you try this? If so there shouldn't be a difference if it's installed on the car or not.
