Brake booster removal
How much has to be removed to get to the bolts for the brake booster? It seems like I can get to all of them except the top right bolt. Is there a trick to get in there, or do I have to start removing interior parts?
Re: Brake booster removal
It helps to remove the big panel underneath the steering column, but I don't remember what all is involved since I did that so long ago....
Knockoff Crew member #0001
The trick is to use a small 3/8 rachet while standing on your head. :]
Billy_Andrea
I took the seat out and put sand bags on the ground outside to make it more comfortable to lay under the dash. A thin extension will get you there. You just need the right light and a wobble ratchet end.
- SidewaysGts
Remove the lower panels, A swivel, some extensions, and bam.
Jeonsah wrote:The trick is to use a small 3/8 rachet while standing on your head. :]
^true story, thats how i did it without taking any interior stuff out
My turd of an 86
20v swapped 86 write-up
My turd of an 86
fantasy_type_0
I pulled off the lower dash panel and have been able to remove all the nuts except for the top right nut. I can barely see it. Do I have to remove the instrument cluster? I am using a 3/8 ratchet with a long extension and a wobble knuckle. Does anyone have any words of wisdom or tips to ease this process? Thank you in advance.
NateTheRipper
no it just takes a little patience to get to it. did this multiple times last month till I gave up on using a booster at all and just going straight master cyl. lol. like previously stated that lower panel is all you need to remove.
05 WRB STI (prostitution whore)
04 Forester XT (sleeper)
97 Blazer (mule)
85 GTS Coupe (Old Lady)
07 TC (sold)
04 Corolla (sold)
89 Supra Turbo (RIP)
85 Supra P-type (RIP)
89 Supra Turbo (sold)
97 Blazer (mule)
07 TC (sold)
04 Corolla (sold)
Not sure why someone revived this thread. Anyway, I used the small ratchet from this set: http://www.sears.com/craftsman-51-pc-ma ... 929309000P
I was able to get in there (by basically standing on my head
), and get just enough room to loosen the nut.
