I picked up a set few months ago.
Been wanting to install it but, before I start drilling holes and such....
can any of you CUSCO Tribar gods chime in on how I should go at this....
and point me in the correct path?
thx mucho in advance fellas!
this is the rear tribar in question:
Help plz CUSCO Rear Tribar Install Help plz
- idreamofdrifting
Re: Help plz CUSCO Rear Tribar Install Help plz
I would fully assembled it and set it in the car to mark where you need to drill. Measure twice drill once.
Knockoff Crew member #0001
- idreamofdrifting
carbd7age wrote:I would fully assembled it and set it in the car to mark where you need to drill. Measure twice drill once.
Sounds good Eric, I will do that!
quick tip. for the piece that mounts to the floor, if you look at the spot from under the car, it goes in between a crossmember and some fuel lines. BE CAREFUL!
- idreamofdrifting
mandm177 wrote:quick tip. for the piece that mounts to the floor, if you look at the spot from under the car, it goes in between a crossmember and some fuel lines. BE CAREFUL!
THANK YOU! I was wondering about that too. Again thx for the very important tip!
I would think some large washers would help as well to prevent the bolts from being pulled through the sheet metal.
- idreamofdrifting
ga_goosh wrote:I would think some large washers would help as well to prevent the bolts from being pulled through the sheet metal.
excellent tip as well Sean! thx brother!
