Hi, for anyone who has made the front end swap, is the radiator support (53216-12927) the same for both Levins and Trueno front ends?
Additionally, are the stamped metal pieces behind the headlights the same, the sub assemblies? (53211-12220 and 53212-12200)?
Thanks
Levin/Trueno Rad. Support and sub-assy the same?
silvertwotones
Re: Levin/Trueno Rad. Support and sub-assy the same?
if you are asking if the levin front will bolt to the trueno rad support the answer is yes. im not sure if they are the same tho
The upper/lower radiator supports are the same. The stamped headlight backing is 99% the the same, only difference is the oem fixed headlight front aka levin has 2 small headlight bracket mounts welded on. Luckily they can be purchased new from Toyota japan and are supplied with self tapping screws and retention nuts. You just need to drill 6 small holes and screw them on if converting from pop up lights to fixed lights.
silvertwotones
Thanks guys!
