ae86 exhaust system clogged
Posted: Fri Sep 27, 2013 2:10 am
hi guy
ok so my car was running pretty nice and smooth . then i notice i have a oil leak due to some not very tight oil relocated kit i have.. so i remove the header to have more room to work with.. after tighten all the line etc.. and put every back and go for a test drive.. i feel like my car have no power ..and feel like the exhaust not letting the air out... after thinking it have something to do with me removing the header and not bolting it back on right i remove and reinstall check everything seem nicely fit. but my car still feel like it choke...and restricted... i then with the engine running look down along the exhaust pipe and FIND that the cat convertor is RED HOT like if you were burning metal in high flame for long time...... is this a sign of it being clogged ? if so what may cause this problem and what to do to fix it?
im thinking just use a test pipe and bypass the convertor ...
or should maybe remove the cat convertor and clean it?
ok i cat convertor remove and installed a test pipe. that didnt help.. still restricted .
notice this is a fully rebuilt 20v BT
new valve new spring new gasket new cam shaft new piston ring new rod bearing ..
