gts vs sr5 bellhousing. difference visually?
Posted: Sun Nov 24, 2013 8:29 pm
by Gabriel82
How can I tell from a picture which is a gts and which is a sr5 before I buy. Please advise. Thanks.
Re: gts vs sr5 bellhousing. difference visually?
Posted: Sun Nov 24, 2013 8:46 pm
by insane
If you had the bellhousing installed in a car then, GT-S will have the clutch fork hole on the passenger side. SR-5 will have it on the driver side.
Posted: Sun Nov 24, 2013 9:11 pm
by Gabriel82
I only have a pix of it off and looking at inside. The clutch fork is on the left and that lump ball looking thing is on the right.
Posted: Sun Nov 24, 2013 11:45 pm
by jondee86
If you are standing at the engine end and looking inside... and the hole where the
fork pokes thru the side of the bellhousing is on your left, then you are a 4AGE. If you
are standing at the gearbox end, the clutch fork and the slave cylinder will be on your
right (passenger side). Unless the bellhousing is upside down..... :?
Posted: Mon Nov 25, 2013 11:39 am
by MisterJerk
Post a pic, we will be able to tell you for sure.
Posted: Mon Nov 25, 2013 12:00 pm
by Gabriel82
Posted: Mon Nov 25, 2013 12:33 pm
by MisterJerk
GTS, 4age t50 tranny, at least bellhousing.
Posted: Mon Nov 25, 2013 12:45 pm
by Gabriel82
Works for me! Thanks.
