BC coilovers
corollin'thecorolla
BC coilovers
Postby corollin'thecorolla » Fri Jan 17, 2014 1:57 pm
Are they bolt-on or weld-on to the 86?
Re: BC coilovers
Postby jondee86 » Fri Jan 17, 2014 3:14 pm
They make both types...
corollin'thecorolla
Re: BC coilovers
Postby corollin'thecorolla » Wed Jan 22, 2014 3:14 am
nice thank you :)
and i was thinking in investing into my suspension before i do my gts conversion. do you happen to know if i can still use all of my suspension parts from sr5 to gts rear end?
morgan
Re: BC coilovers
Postby morgan » Wed Jan 22, 2014 8:18 am
yes, everything will bolt up(sway bar and associated hardware, panhard bar, 4 links, shocks, springs)
My turd of an 86
20v swapped 86 write-up
Re: BC coilovers
Postby yoshimitsuspeed » Wed Jan 22, 2014 8:32 am
I can get BC coilovers. PM me if you are interested.
corollin'thecorolla
Re: BC coilovers
Postby corollin'thecorolla » Thu Jan 23, 2014 2:58 am
Would there be a performance difference on the two? Or is it just a preference of having the strut and coil together?
& I'll get back to you on that yoshimitsuspeed.
Re: BC coilovers
Postby MisterJerk » Fri Jan 24, 2014 12:26 pm
they are the same. one has spindles. the other you have to weld your spindles onto them.
corollin'thecorolla
Re: BC coilovers
Postby corollin'thecorolla » Mon Jan 27, 2014 1:35 am
thank you my good sir. i appreciate the share of knowledge. now just one more question if it's not a bother. on a celica supra rear end conversion will coil overs have to change? or would they both work?
boogaov
Re: BC coilovers
Postby boogaov » Tue Feb 11, 2014 1:49 pm
yoshimitsuspeed wrote:I can get BC coilovers. PM me if you are interested.
Pm'ed
