Just bought a silvertop
Posted: Tue Jan 15, 2013 1:04 am
by Spoold86
any tips from previous builders? I'd like to rebuild it, (piston rings, valve guides, etc) anybody know where i can buy rebuild parts? or if/what 16v parts are compatable
lol What about keeping the 20v block but using a red/bluetop head? i hear some talk about this but id just like to get club4ag's opinion
Re: Just bought a silvertop
Posted: Tue Jan 15, 2013 11:38 am
by HASport AE86
You can use alot of USDM parts for this engine.
-AE92 GTS oil pump
-AE86 Water pump with RWD housing
-AE86 timing belt tensioner
-ST timing belt (you can order this timing belt at your local Toyota Dealer even though it's JDM)
-The valve guide seals are Toyota Echo valve guide seals
-The rings you can get from NPR here in the USA
You can use the 20v bottom end with the 16v head, people do it all the time. You can actually just slap the two together if you want but the 20v pistons blow dog nuts. I built a motor a few months ago using high comp 16v pistons and a silvertop bottom end. The high comp pistons you can get from RockAuto for $84.00 for all four pistons.
Posted: Tue Jan 15, 2013 6:33 pm
by Zenki85
HASport AE86 wrote:You can use the 20v bottom end with the 16v head, people do it
What are the pros to this?
Also thank you for Info In other forum HASport ! Thumbs up!
Posted: Tue Jan 15, 2013 6:55 pm
by HASport AE86
Zenki85 wrote:HASport AE86 wrote:You can use the 20v bottom end with the 16v head, people do it
The ST bottom end has larger rod journals, oil squirters to keep the pistons cooler, and stronger thicker rods. It is also physically a stronger engine block with more reinforcement ribs. Just slapping a stock 20v bottom end to a 16v head is called a "1620 Engine". The stock silvertop pistons are junk though in terms of squish area and blah blah blah math blah blah. Good little setup is to find a silvertop engine that some fanboy bought and tore apart never re-assembled and pick yourself up some 0.50mm oversized high comp 16v pistons off RockAuto.
Posted: Tue Jan 15, 2013 6:57 pm
by HASport AE86
I'm going to have to go and do ALLLLLLLLL my write ups all over again. So lame. So lame.
Posted: Tue Jan 15, 2013 7:27 pm
by Zenki85
HASport AE86 wrote:I'm going to have to go and do ALLLLLLLLL my write ups all over again. So lame. So lame.
How much gains in performance?
Posted: Wed Jan 16, 2013 8:38 am
by HASport AE86
Not so much a performance gain as peace of mind and reliability. If you want performance you could get a BT bottom end, they have the lightest rods, will help with throttle response.
Posted: Thu Jan 17, 2013 2:44 am
by Spoold86
Wow thanks fellas
Posted: Thu Jan 17, 2013 2:46 am
by Spoold86
can you remember the part numbers for the pistons, and if i do so will i have interference? xD
Posted: Thu Jan 17, 2013 8:32 am
by HASport AE86
I'll have to dig around for the part numbers. If you put 16v pistons with a 16v head, they are not interference, regardless of the 20v bottom end. 20v engines however ARE interference no matter what someone says. They BT head I had with bent valves is proof.
Posted: Thu Jan 17, 2013 3:32 pm
by John H.
Do it, do it, do it!
