streering wheel questions
darkblues24
I really hope someone can help me out on this problem that I have. My steering wheel keep changing direction, for instance one day it could be as straight as possible when driving straight, but when I turn right and the steering wheel is crooked to the right and when I turn to the left, the steering wheel is crooked to the left when I drive straight. it happens with every turns I take. It does not feel loose or anything, I just don't know what the problem is. my car power steering btw. Thanks for the help guys!!
Re: streering wheel questions
What front suspension are you using and in particular, what top mounts ?
darkblues24
oem, the car is completely stock
Ok that gets that out of the way (assuming your top mounts are in good condition)
Try jacking the front wheels up off of the ground and turning the steering from lock to lock without the engine running, check for any tightness.
Then with the front still up in the air, centre the steering wheel and start the engine. The wheel should stay where it is.
You may have air in the power steering system so you could also try bleeding it.
darkblues24
thank you bud!! but when I turned the steering wheel without the engine running, I don't feel any slacks or anything. It felt really tight. ill try to center the steering with the front up in the air. what would be the indication if the wheel doesn't stay where it is??
darkblues24 wrote:thank you bud!! but when I turned the steering wheel without the engine running, I don't feel any slacks or anything. It felt really tight. ill try to center the steering with the front up in the air. what would be the indication if the wheel doesn't stay where it is??
Hopefully just air in the system that can be bled out or a loose power steering belt. Make sure all of the pullies move freely on the P/S system.
Try turning the steering with the wheels off of the ground and the engine running to see if there is any pulling etc.
- ToeKnee805
check your inner tie rods for play. Chances are they are the original ones from 1986
darkblues24
Tie rod end has been changed btw..
- ToeKnee805
not tie rod ends, inner tie rods. the ones that screw into your steering rack, not the ones that bolt onto the knuckle
SgtRauksauff
make sure that your steering rack bushings are actually holding it in place. with the wheels on the ground, have someone else turn it while you watch to make sure that it stays in one place and doesn't move. if it's still the original rubber bushings, they may have finally deteriorated, allowing the rack itself to move a bit....
darkblues24
with the engine running, when I turned the steering wheel right and left there is about 1/8 of a turn I saw a slack where the wheels doesn't turn along with the steering wheel. What the problem could be??
Sounds like the rack might be worn, but check your tie rods. All my corollas have had worn ends, either outer and inner or both. You can detect this by leaving one wheel on ground, jack the other up, then grab wheel at sides and rock it feeling for play. You might as well grab wheel top and bottom and try rocking that too, that usually means ball joint.
SgtRauksauff
It almost sounds liike the steering column shaft might have some stripped splines, or a loose bolt-clamp, so it's not actually turning things.. I'd start there and work towards the wheels.
Could also be a tooth or two broken off of the steering rack gears, but that's really something that happens even less frequently than worn steering rack teeth, which is also highly unlikely.
Does the movement or lack of movement affect both tires at the same time, or only one of them? I.e., when you turn the wheel, does the left tire turn immediatly, but the right tire delay for the eighth-turn, or do both tires start moving at the same time after the eighth-turn?
Were you able to ensure that the steering rack mounts and bushings were solid by verifying that the steering rack is immoblie while the wheel is turned?
