___________________________________________________________________
Purchased mint condition door panels from my local yard with minor nicks.
Time to fix it. After quick research on the web, I have decided to try this. Only $8.00 at Walmart.
(There are better version for $15.00 from the same company as well that include electric iron that I think it is easier to use.)[/b]
Follow the instructions and create a crator at a damaged area with razor blade or hobby knife.
Fill the damage area with filler that is included in a repair kit
Let it dry for 4 hours and then, apply black color on the damaged area,
then, create that "OEM pattern" with pattern sheet using provided heating tools.
(Just follow the instruction...it is easy).
According to the instructions, this complete the repair but, I did not like the result.
Therefore, I have decided to paint the panel with Duplicolor Vinyl Interior Paint (Flat Black).
Then for that final touch, apply Armorall or similar products to make vinyl shine!
Step back and look at the final result and smile.
(Yes, if you look carefully, you can tell the repaired area but good enough for DIY level .)
