20v smallport inlet
20v smallport inlet
Postby totta crolla » Mon Nov 27, 2017 10:56 pm
Competition regulations that I need to adhere to state that I must use a single throttle body on the inlet and the manifold must be standard. I can get away with using a modified smallport manifold and I wondered how different the port spacing etc is compared to a blacktop 20v head ? Is the 20v head flow advantage over a smallport head worth the effort ?
mad_86
Re: 20v smallport inlet
Postby mad_86 » Wed Nov 29, 2017 10:46 am
you can house the itbs to single intake hopefully they wont notice lol
https://goo.gl/images/QCngtS
If not MRP has what your looking for they use it for turbo set up but you will need a custom throttle body and wiring
https://www.mrpltd.co.nz/product/4age-20v-plenum/
Postby oldeskewltoy » Wed Nov 29, 2017 11:15 am
totta crolla wrote: Is the 20v head flow advantage over a smallport head worth the effort ?
On stock form the Blacktop head will easily outflow a stock smallport head. Flow @ 9mm lift is usually about 180cfm for a smallport, and about 190 cfm for a stock Blacktop. But total numbers are only part of the story... at lower lifts, the 20V EASILY outflows a 16V.
The real difference is in the exhaust, a stock 16V exhaust flows a max of 120cfm, where as the Blacktop is closer to 135.
slight porting on the intake side of a smallport quickly removes any intake advantage at full lift, but the lower lift advantage to Blacktop can't easily be overcome.
The exhaust side of a 16V needs a lot to flow similarly to a Blacktop.
Postby oldeskewltoy » Wed Nov 29, 2017 11:23 am
As to port spacing... this is an adapter designed to mount the entire Toyota 20V ITB system to a smallport head.... port spacing should be dead on
Postby totta crolla » Wed Nov 29, 2017 12:21 pm
Very interesting re. flow figures and it looks like it might be worth the effort.
I wonder what the chances are of the inlet manifold studs lining up are ?
The turbo plenums are very nice but they look 'modified' as far as the scrutineers are concerned.
Postby oldeskewltoy » Thu Nov 30, 2017 3:50 pm
biggest problem as I see it... the 20V manifold flange is angled, while the 16V manifold is not... likely need to do a bit of creative machining, or maybe make a small adapter......
jinx
Postby jinx » Thu Nov 30, 2017 5:57 pm
Users browsing this forum: davew7 and 1 guest
