full weight street car. Top effort https://www.youtube.com/watch?v=S4EpVHR3liE
so much for the "weak & shitty" box reputation, eh
It was rumoured that PSI mid 10sec(et ~1990) full street 3TC KP61 starlet, used a stock GTS T50. 3ft wheelies!!
Wonder where's(or if) the magic.... moded, fluids, and what not ?
Stock 5 speed 550hp 4AG AE
Re: Stock 5 speed 550hp 4AG AE
PSI street starlet, back in da day
Wow, and i was wondering if the 20v ST would cause problems. no worries now!!
Great to hear his story, weird seeing an ae86 be fast
1986 SR5->20V ST (WIP!)
jinx wrote:full weight street car. Top effort https://www.youtube.com/watch?v=S4EpVHR3liE
He changes gear like he's driving a stock T50. I'd guess he broke a few back
in the day and learned how to treat them nice
E-chassis rollas been 'fast' for decades
that's key imo. Shock kills most... like torque meets traction, launches. Stock 4AG can break a T50 if you're dumb enough
Good to see the T50 'selects' fine, at rpm and with a hefty torque increase(over stock). Fluid maybe ?
Gearbox upgrades significantly heavier. Cool to see the puny T50 live behind such a high strung street car build. Corolla veteran
Trans oil/fluid? I found an oil, Ford offering, that has additives to reduce friction and EP additives that do a fantastic job, maybe too good. Check with your Ford dealer.
Reducing gear endplay keeps more face contact with the gears. Straight gears tend to be better as well. Reducing endplay also helps with engagement extending synchro life.
One shot, one kill.
This Ford oil.
Is it deep red by any chance?
be careful of what you put in any gearbox, as it may cause damage. I'd search recommendation specifically for the T50
For instance,
My Ford escort GT 5 speed fluid was dark red.... yep, auto transmission fluid, from the oem manual
Some Buick GN turbo folks run John Deer tractor hydraulic fluid in their beefed up autos
For instance,
