A/C for 20v swaps?
Kuromi_loves_toyota
A/C for 20v swaps?
Postby Kuromi_loves_toyota » Mon Jan 02, 2023 12:38 am
im in the process of 20v swapping my corolla, i dont really know what to do about climate control, can i just use an A/C compressor and other components from any old 86, should i look for a smallport compressor, or should i try and source a compressor from a 20v? i have the condenser, heater core, and all the piping needed, i just need a compressor. all help is appreciated
"be creative and live a fun life, and dont be an asshole" KB43VER
Iggylevin
Re: A/C for 20v swaps?
Postby Iggylevin » Wed Feb 15, 2023 9:57 am
For the easiest setup is to use the rwd 16v compressor and (someone correct me if I'm wrong) rwd main pulley. Iirc if you use the 20v pulley there's some shaving involved.
Kuromi_loves_toyota
Postby Kuromi_loves_toyota » Thu Feb 16, 2023 1:39 am
would, the condenser and other components from my SR5 still work?
Iggylevin
Postby Iggylevin » Wed Feb 22, 2023 11:12 am
Everything from the sr5 is compatible but the compressor because it's a single rib pulley. If you use the sr5 compressor you would need need to swap all the pulleys from the sr5 to the 20v to make it work.(I've only seen it done on a 16v but in theory should work on the 20v)
Kuromi_loves_toyota
Postby Kuromi_loves_toyota » Thu Feb 23, 2023 12:42 am
i believe the AC compressor that denso sells comes with the pully on it, ill just need to find a new accessory belt
Iggylevin
Postby Iggylevin » Thu Feb 23, 2023 2:06 am
That is correct. Good luck with your project :D
Kuromi_loves_toyota
Postby Kuromi_loves_toyota » Thu Feb 23, 2023 3:27 pm
thank you!!, ill post how it goes, and i hope the same setup works when i eventually go 7A
sirdeuce
Postby sirdeuce » Thu Mar 02, 2023 9:08 am
If you can't get the A/C working just use the good 'ol 2/75.
One shot, one kill.
Kuromi_loves_toyota
Postby Kuromi_loves_toyota » Tue Mar 14, 2023 1:17 pm
can you explain? im not very familiar with climate control systems.
kiosk
Postby kiosk » Tue Mar 14, 2023 1:45 pm
pack
Postby pack » Mon Aug 07, 2023 4:33 am
Iggylevin wrote:For the easiest setup is to use the rwd 16v compressor and (someone correct me if I'm wrong) rwd main pulley. Iirc if you use the 20v pulley there's some shaving involved.
I've always heard this one... you need to shave the compressor mount to align both pulleys right?
The idler, and compressor pulleys to be precise.
Kuromi_loves_toyota
Postby Kuromi_loves_toyota » Wed Aug 09, 2023 1:32 am
kiosk wrote:Image
:lol:
