I'm pretty sure the noise isn't a "howl" from a bad pinion, but the vibration sounds similar to as if a pinion bearing was going out. From searching around online this sounds like a drive shaft issue, but not entirely sure. When decelerating from 45mph, if I apply a slight amount of braking it helps to get rid of the vibration. Also, the vibrations definitely were louder on my first "break in" drive on my new setup and are actually a bit quieter now after driving it for a few days. Idk if its just because the diff is still new and I don't have it "broken in" with a few hundred miles on it or if it is my drive shaft u-joint ... Anybody have some input on this?
*And no it is not the welded diff chirping noise thing from making turns
