2013 f20 86 build round 2
nt66
Postby nt66 » Tue Jan 22, 2013 4:06 pm
Since i finally moved into the current century and have a phone i can post with thought I'd go ahead and share the new shell......... this car had been around for a while but just became mine officially last week going to try my hardest to have it finished for April
nt66
Re: 2013 f20 86 build round 2
Postby nt66 » Tue Jan 22, 2013 4:08 pm
spent the weekend getting parts for this thing so we hit the road to kingsbury tx
finally found a rear end
nt66
took the car up to dallas
knocked the rest of the sound deadaning out of it
Dropped it off at Auto Comp Racecars in Ft. Worth for cage and suspension work
also got the engine for her
nt66
Postby nt66 » Tue Jan 22, 2013 4:10 pm
finally made it up to ft worth/autocomp this past weekend (sorry dallas/ftworth bros spent the whole time working)
finished getting every last bit of sound deadaning out
chopped the front wheel wells out
along with the spare tire well
this is what she weighs in the current state should have the cage going in soon then its on to rear suspension design
also bought this thing to tow with but i'll start a new thread somewhere else
nt66
Postby nt66 » Tue Jan 22, 2013 4:11 pm
updates!!!
marking floor for main hoop
the man marty hard at work
trying to mark out line on the floor but having trouble
switched to cardboard
bending main hoop
notching stuff up
nt66
Postby nt66 » Tue Jan 22, 2013 4:12 pm
Autocomp TIG welding awesomeness
bent up the front HALO bar started notching it
pulled the green car in for temporary destruction
rolled here out back :(
mocked motor up in the new car
started cutting for shifter clearance
nt66
Postby nt66 » Tue Jan 22, 2013 4:13 pm
rolled her out side
cut out tunnel for transmission clearance since I can no longer run subframe spacers
Honda rue made me a fancy map sensor delete and one for the brake master
motor back in
main hoop all finished
went to pull some more stuff and found a odd motor swap
nt66
Postby nt66 » Tue Jan 22, 2013 4:16 pm
started beating inner fender for wheel clerance
motor all cleaned up
trans final cut
welding magic
halo bar fitting
more welding
tilted foward for welding the tops
bent front down bars
Deuce Cam
Postby Deuce Cam » Tue Jan 22, 2013 4:44 pm
I didn't notice any subframe spacers. Were you able to avoid using them by cutting the trans tunnel for clearance?
nt66
Postby nt66 » Wed Jan 23, 2013 7:43 am
Deuce Cam wrote:I didn't notice any subframe spacers. Were you able to avoid using them by cutting the trans tunnel for clearance?
exactly... I was running the subframe spacers on the green car but can't run them on the new car because of the rules. Had to cut the trans tunnel out for clearance and I will probably have to cut a small hole in the hood to clear the end of the valve cover
carbd7age
Postby carbd7age » Wed Jan 23, 2013 1:24 pm
What was wrong with the green car? It looks so sad outside all alone. :|
Knockoff Crew member #0001
Zenki85
Postby Zenki85 » Wed Jan 23, 2013 2:24 pm
Oh yes I think I've heard of that. One of 2013's new rules. I think I read it in one of DMACs ae86 read ups on speed hunter he enforced his tunnel real well.
Great build!!!!
TEAM 'CLASSIC
A 'CLASSICALIFORNIACAR
Adriansadriano@yahoo.com - email
nt66
Postby nt66 » Tue Mar 19, 2013 6:26 pm
so its been a little while since i made some updates so here are some!
finished beating the inner fender well flat for wheel clearance
got the front down bars welded in along with the floor plates
perfectly straight fenders..... not for long
Marty taught me some basic lathe skills and i turned the new steering rod down to fit in the stock joint
nt66
Postby nt66 » Tue Mar 19, 2013 6:27 pm
new fuel cell
got fancy with the wiring thanks to brad for the mil spec parts
new fancly quick connect fittings and lines from toxic fab for all my vaccum lines
super expensive sfi rated fire supression system
spec clutch and flywheel for the new car
new front wheels that still need to be painted white
nt66
made the trek back to auto comp
new surge tank
got wild with the new cell put a pump inside to feed the surge tank
made it all fit
nt66
Postby nt66 » Tue Mar 19, 2013 6:29 pm
threw the new clutch and flywheel on even thought the old one held up very well
had to build a new crossmember the old one would not pass fd tech it had to much welding on it
nt66
mil spec all finished up
made brackets to hold the fire bottle
painted the engine bay
sweet new dirt track steering wheel
manual rack all pretty
motor going back in
new found angle with the manual rack
never had this problem before lol
started figuring out seat brackets
new seat
turbo all shined up
fun with carbon
as she sits right now
mtmetzger
Postby mtmetzger » Wed Mar 20, 2013 7:31 am
Nice progress! This thread makes me feel like I'm taking short cuts on my F22c build! :)
Also, Can you post some details of how you did / are going to do the drive shaft?
Warren
Postby Warren » Thu Mar 21, 2013 11:01 am
Top notch work, looks like you chose the right shop!
marley4us
Postby marley4us » Thu Mar 21, 2013 11:35 am
holy crap thats bad ass
1994 4runner (The truck)
RuizXIII
Postby RuizXIII » Thu Mar 21, 2013 7:32 pm
I wonder what that dude was saying in that last pic...
Pretty sweet work here, man. Engine looks fierce.
irony.cc
nt66
Postby nt66 » Fri Apr 26, 2013 2:48 pm
more updateeeeesssss
chopped up some swaybar end links to make them fit
finished up my fuel tank set up
now that the engine sits so much higher the hood would no longer close..... Fixed that
new anti intrusion bars added
nt66
Postby nt66 » Fri Apr 26, 2013 3:13 pm
coming together....
ran out of time to finish my celica supra rear so had this old man help me rob it off the other car
rolled it out side and painted it
door bar madness
nt66
Postby nt66 » Fri Apr 26, 2013 3:35 pm
fd spec brake lights
made a ecu mount out of my anti intrusion bars
lucky13evo
Postby lucky13evo » Fri Apr 26, 2013 11:29 pm
No one will ever intrude your car now. lol sweet build
yellowsnow4free
Postby yellowsnow4free » Fri Apr 26, 2013 11:59 pm
Great build! :D All the pics are great; thanks for taking the time to upload and comment on them :)
nt66 wrote:Image
Just out of curiosity, the pieces that were cut off the car... they weren't scrapped right? I hope not; they are perfectly straight :)
nt66
Postby nt66 » Fri May 24, 2013 5:32 pm
So i am going to jump ahead i little bit the last weekend after the last picture in this thread was total chaos with almost no sleep to finish the car in time for long beach. At one point i worked for 40 hrs. straight through only stopping for food and water. So needless to say I don't have a lot of pictures of us finishing the car lol. We ended up finishing the car and putting it on the trailer at 8:30 am on Wednesday and we had to be in long beach at 10 am on Thursday... it was a pretty interesting drive without a whole lot of stops.
We ended up pulling up to the track at around 10:30 am and unloaded the car and headed to tech. Formula D tech is pretty in depth so i was nervous about passing but in the end the only thing we had to add was a driveshaft loop.
We got it installed and made it official. After finishing a few things up that we didn't have time to finish in Texas we headed to the hotel for the night. The next morning started with a drivers meeting explaining all the things the judges would be looking for. I had never driven the new car so i wasn’t sure what to expect heading into the one and only practice session.
On my first run in practice I decided to go for it on the straight knowing we would only get a few runs before qualifying. The car felt good in first and second but when i shifted to third I had a massive boost spike in the 35-40 psi range. Turns out the wastgate/boost controller had malfunctioned causing the spick. I headed back to pit road to fix the problem but the damage had already been done. With the help of vene we got the wastegate working again but the car started overheating. I started to worry that we had blown the head gasket but headed back to grid to try to make some runs anyway. My second run the car was way down on power and it started smoking slightly the run wasn’t that great as i was still trying to figure out the track. My third and final practice lap all the problems became much worse the engine dumped smoke throughout the entire run, started overheating again, and was even more down on power. We checked the oil level on pit road and we had burned an entire quart in one run. After much debate I decided to retire from the event and save what was left of the engine. It was a tough break after all the work we put in to make the event but it was the best decision in the end.
nt66
After getting the car back to Texas i quickly got to work trying to find the problem. After a compression and leak down test it was apparent that we had lost the number three cylinder. I pulled the car in the garage and started pulling the engine.
the culprit.....
nt66
Postby nt66 » Fri May 24, 2013 5:35 pm
going to leave this here as well
http://www.vimeo.com/66694221
boosted86
Postby boosted86 » Sat May 25, 2013 9:58 am
Top notch build! Really quality work on the whole car. Bummer about the cracked cylinder!
