fd caliper
Re: fd caliper
I've seen people grind off the logos and bumps to help with rim clearance.
						Re: fd caliper
i see on the fc, but not the fd.
						Re: fd caliper
go for it with a dremel bro, it will be easy
						Re: fd caliper
thanks alot for the picture
						Re: fd caliper
Has anybody tried mounting evo 7/8/9 calipers onto the 86 bracket kit that people make to mount fc/fd? Because the evo 7/8/9 calipers are direct bolt on to the FD's so I'm assuming the mounting points are the same locations.
						Re: fd caliper
I would also like to know this too.. Having an evo caliper would be awesome!
						Re: fd caliper
tchybrid wrote:I've seen people grind off the logos and bumps to help with rim clearance.
On the FC Calipers... don't grind off the bumps. There is a fluid passage in there. One of guys that bought my brackets did it and had to find another caliper. The FD calipers shouldn't have any problems.
"Working on cars is not what I do... it's who I am."  Steve Metcalf
						Re: fd caliper
grinding it off flush should be no problem, it'll look better too...!
