remove throw out bearing
Stock4AG
Postby Stock4AG » Sat Oct 19, 2013 7:08 pm
I want to sell my clutch but include the throw out bearing
Can you tell me how to separate the bearing from the part with the 2 ears that the clutch fork attaches? (Not sure the name, release hub?)
I remember the clutch just come with a round throw out bearing, I think.
By the way its the illegal garage clutch..
Thanks alot
Stock4AG
Re: remove throw out bearing
Postby Stock4AG » Mon Oct 21, 2013 10:20 am
it looks like this. I have a socket and a bearing separator kit.
Does anyone have pic of what the release hub body look like?
morgan
Postby morgan » Mon Oct 21, 2013 12:01 pm
you need a press, push the center piece out
My turd of an 86
20v swapped 86 write-up
BakaBaka
Postby BakaBaka » Mon Oct 21, 2013 12:50 pm
^ what he said.. only way of removing it. If you don't have access to a bench press.. you can always go look for a bearing puller tool. But good luck with the second option.. the bearing is pressed in there good.
Stock4AG
Postby Stock4AG » Mon Oct 21, 2013 4:56 pm
Thanks, I got it out, I used a non-hydraulic press and it wasn't on there too tight
flowisode_zero
Postby flowisode_zero » Mon Oct 21, 2013 5:59 pm
Ive taken these off multiple time with just a hammer, tap and a socket. For putting everything back together, put the housing in the freezer. Bearing will slide on easily with only a couple taps with a rubber mallet and a block of wood to distribute the load and seat it evenly.
mad_86
Postby mad_86 » Thu Oct 24, 2013 11:37 pm
flowisode_zero wrote:Ive taken these off multiple time with just a hammer, tap and a socket. For putting everything back together, put the housing in the freezer. Bearing will slide on easily with only a couple taps with a rubber mallet and a block of wood to distribute the load and seat it evenly.
+1 i also use this method ,..without the freezer part tho lol
carbd7age
Postby carbd7age » Mon Oct 28, 2013 2:45 pm
I used a bench vise to support the bearing with the hub hanging down. Put a socket on the hub that would fit inside the bearing and gave it a whack. Mind your toes, but it works like a charm.
Knockoff Crew member #0001
MisterJerk
Postby MisterJerk » Tue Oct 29, 2013 11:01 am
I did mine "Taka" style. Jack stand, hammer, large socket. Bam bam, done. clean the **** out of everything... Bam bam bam back on with a larger socket. Luckily, I have a bunch of monster sockets. 15/16, 1" makes it easy.
