so i got started on one of the 2 free doors i recently got(big thanks to the guy who helped me out after the body panel fiasco i encountered), over the weekend. passengers side. some rust underneath near the drain holes, removed all seam sealer down there too.
looks like they were sitting outside for some time.
wire wheeled the rust
this corner was the worst, since it appears the door was dragged a good distance, so theres a flat there and the layers are seperated. i need to fix that up.
pulled the side moulding off to see that it wad been resprayed at one time, and they masked off the moulding...crapola, what am i in for?!
not too bad, 2 seperate dents, but from the inside they look minor. sanded the outside completly, just need to remove the bondo and lay down some plastic body filler there, por-15 the rust inside and out, then scuff the inside areas for paint.
once i get the doors done, ill stick them on the car and weld up the fender repairs. those pieces are all done, just need to weld them in.
