I'm interested in the block but I need to know if the block can be bored and the crank turned or are they both worn out. Do you have, or can you get some measurements of the cylinder bores and crank journals? Thanks.
WSRdriver wrote:I'm interested in the block but I need to know if the block can be bored and the crank turned or are they both worn out. Do you have, or can you get some measurements of the cylinder bores and crank journals? Thanks.
