FX GTS igniter with ae86 wiring
garebare8520
Postby garebare8520 » Tue Sep 16, 2014 2:59 pm
Desperately looking for the igniter/coil connector pinout for an ae82 FX GTS. Correct me if I'm wrong but the pinout for the ae86 should look like this:
IGT=Black
IGF=Black/Yellow
Tach=Black
IGN+=Black/Orange
NE=Red
The colored wires of the ae82 FX GTS are as follows: Beige, Green, Yellow, Light Blue, and Gray. Any help would be much appreciated.
allencr
Re: FX GTS igniter with ae86 wiring
Postby allencr » Tue Sep 16, 2014 10:14 pm
From factory manual RM069U 1988 Corolla FX/FX16 US & Canada
There's no light blue or beige in the color chart.
Igniter pins> 6=B, 1=B, 4=B-Y, 2=W
ECU terminals> NE=W, IGF=B-Y, IGT=B, G+=B, G-=W
garebare8520
Postby garebare8520 » Fri Sep 19, 2014 12:30 pm
Thank you for the quick reply. I have tried to post a picture with no avail so I will try to be as descriptive as I can. I will try to pull one from the web. When I went to Toyota to identify it they said it was from an 87 fx16 so I dont know if the wiring diagrams are interchangeable. Also the 2 wire round plug going to the distributor is the early style plug usually on ae86's while the 5 wire plug is the later style plug square in shape. Part #''s for Igniter Assy is 89620-02010 and Coil w/Igniter is 19070-02010. Any help is appreciated.
garebare8520
Postby garebare8520 » Sun Sep 21, 2014 9:53 am
Another link to the igniter coil I want to install on my ae86.
jrae82
Postby jrae82 » Tue Sep 23, 2014 6:19 pm
I'm running ae86 igniter on my fx16 with no problem. I just spliced that dizzy plug that is different. Color match the wiring. Been running it for a year now. Hope that helps
garebare8520
Postby garebare8520 » Mon Oct 06, 2014 12:12 pm
Thank you for the replies and sorry for not being more specific. Finally got my ae86 running with some educated guesses. This is if you want to install 87-88 fx16/GTS into an ae86. Now I need to figure out why my exhaust gets so hot within seconds, I'm thinking TPS or timing.
fx16 ae86
Green------Red
Grey--------Black/yellow
Blue--------Black
Brown------Black/orange
Yellow-----Black
Postby jondee86 » Mon Oct 06, 2014 1:24 pm
garebare8520 wrote: Now I need to figure out why my exhaust gets so hot within seconds
Usual cause is retarded ignition timing. Use a timing light to check.
