vacuum ports for carburetor synchronizer?
choyr
Postby choyr » Thu Feb 05, 2015 7:50 am
Are there vacuum ports for each throttle that can be used for example a Motion Pro carb synchronizer? I just want to check my 4AGE 20V blacktop's intake.
Re: vacuum ports for carburetor synchronizer?
Postby jondee86 » Sat Feb 07, 2015 1:02 am
There are no vacuum ports on the ITB's suitable for plugging in
your synchronizer. You would need to drill and tap a into the throats
somewhere. And as the throttles are "equalised" via the idle air
ports and the common vacuum rail, I doubt that the results would
be worth the effort. Better to use an airflow meter that plugs
into the mouth of the ITB...
choyr
Postby choyr » Sat Feb 07, 2015 4:35 am
thanks jondee!
PDB
Postby PDB » Sat Feb 07, 2015 5:48 am
Haha I'm literally using that very tool now to set my carbs on my 16v, it works a treat [emoji106]
Don't think it matters but mine are now pulling around 6 on the meter at idle
