4age 16v shim retainer
Re: 4age 16v shim retainer
Postby totta crolla » Thu May 07, 2015 9:15 am
speedmaster wrote:Maybe try asking supertech if they have such retainer. It's a waste not to use the toda shims
It's unlikely that the Toda shims will all fit without modification.
speedmaster
Postby speedmaster » Thu May 07, 2015 9:16 am
i can acquire 3szfe buckets. do you think that will work? its from 1.5L engine
Postby oldeskewltoy » Sun May 10, 2015 8:41 am
**IF** the 3SZ-fe uses the same buckets as the 1SZ... then yes.... but as I've described they are not easily acquired here in the USA
turboae92
Postby turboae92 » Mon May 11, 2015 7:40 pm
Check this vendor on ebay his from Australia and he sales the shimless bucket at about $8. Each.. http://m.ebay.co.uk/itm/271860212924?nav=SEARCH
I'm researching the 80's and 90's yahama bike for their lifters it may work for us some have under bucket shim like toda and some solid like yaris.
Postby yoshimitsuspeed » Mon May 11, 2015 7:43 pm
You should measure your shim. I can get pocketed retainers for 14mm and 9.5mm. If they are another size I might be able to get you something made.
speedmaster
Postby speedmaster » Wed May 13, 2015 7:37 am
turboae92 wrote:Check this vendor on ebay his from Australia and he sales the shimless bucket at about $8. Each.. http://m.ebay.co.uk/itm/271860212924?nav=SEARCH
thanks bro
turboae92
Postby turboae92 » Wed May 13, 2015 6:21 pm
No problem..hey off topic you should do a build log about the modification on you race ae92..
speedmaster
Postby speedmaster » Wed May 13, 2015 8:51 pm
turboae92 wrote:No problem..hey off topic you should do a build log about the modification on you race ae92..
Its a build since 2012. Lols. There is a lot to write... But I do wish to make a blog about it
speedmaster
Postby speedmaster » Wed May 13, 2015 8:53 pm
Here is the latest dyno chart. 2014 vs 2015. Gonna go more by next week with a few more mods
turboae92
Postby turboae92 » Fri May 15, 2015 3:08 pm
Those are good numbers.Its a 1.6 or 1.8l and compression??
