Daihatsu Charmant
jdm86gtz
Re: Daihatsu Charmant
Postby jdm86gtz » Tue Jan 29, 2013 6:50 am
Got her back tonight so the final build can begin now
Painted in 2 pack it's a Fiat colour from maybe 1856.
jdm86gtz
Postby jdm86gtz » Tue Jan 29, 2013 6:52 am
I don't have to flock the dash as I got a decent colour dash from Cloko.
Had to repaint everything (crossmember etc.) and have fitted a few bits so far. It's getting busy already in the engine bay :thumpsdown:
You can see the braided brake hoses heading off in through the bulkhead where I'll mount a T piece to split the fronts and rear bias valve before reconnecting back to the hard line for the rear brakes. No hydraulic handbrake for now. Fitted a small oil catch can behind the R/H headlight
W58 with adaptor bellhousing, also came with 212mm Illegal Garage clutch disc
jdm86gtz
Got the brake hoses sorted, just have to P clip up the hoses in the front.
Mounted a Jap rear bias valve and a T piece up behind the heater box and ran the hoses out through the wiring loom grommets. Sent the rear hose down through the tunnel and connected back to the hard line
jdm86gtz
Postby jdm86gtz » Tue Jan 29, 2013 6:53 am
Finished my dry cell battery fitting today, Nutserts are great yokes. 200 amp trip switch fitted along side the battery.
Edit I'll probably have to redo the battery mounting to something more secure.
jdm86gtz
Postby jdm86gtz » Tue Jan 29, 2013 6:54 am
Fitted the gold heat reflective stuff which is a pain to fit. It is like window tint and only like flat surfaces
Nice shiny Toda pulleys
jdm86gtz
Sealed up the engine a couple of weeks ago and fitted it along with a T50 for now(W58 sitting there patiently)
I know way back I said 2 seats and not much else but then Cloko had a decent interior for sale so I bought it, Then I got 2 black and grey Recaros and some bright spark said I should get the rear seats reupholstered to match. Also kicked a rear bumper off a scrap Charmer. Mostly wiring left to do as I removed a lot of unnecessary underdash wiring from the loom and finish the engine loom.
Getting it ready to get a full stainless exhaust made from turbo to tailpipe. I'm thinking an oval rear box something like the HKS Legal on my Trueno.
Oh yeah bolt in sump baffle fitted
jdm86gtz
Postby jdm86gtz » Tue Jan 29, 2013 6:55 am
I wasn't happy with the front 7" -12 wheels so I bought a pair of 8" 0 offset and wrapped them in Advan AD08 Neova tyres now I can get the cool Advan sticker for my wings like all those Hondas. Also wasn't happy with the AE86 front struts so I got another pair of Charmant struts, going to get them sand blasted and I guess I should convert them to coilovers also.
jdm86gtz
Postby jdm86gtz » Tue Jan 29, 2013 6:56 am
I'm trying to do something to this every day even if it's only 1 small job it's something off the list and closer to completion.
So the clutch hose, and fuel feed hose are done. Still have to mod the clutch pedal before the clutch is off the list.
jdm86gtz
One of the lads did a bit of work on the exhaust for me. He had advised me to buy a mandrel bent 90 degree and two 45 degree bends so I bought them and he Tig'd them together with a few inches of straight added in here and there. I still have to decide what to do exactly for the rest of the exhaust though, I was thinking of dropping it from 3" back down to 2.5" around where the cat would be on an AE86 or just go as far as the cat and run an AE86 catback.
Anyway I waited until it got dark to take a picture of course. Really had to cut the 90 down to make it past the bulkhead even with the bulkhead area flattened out. I hope it won't cause issues being too close to the turbo.
jdm86gtz
Postby jdm86gtz » Tue Jan 29, 2013 6:57 am
Got MCN inserts and made up coilovers with 450lb/ 8kg/mm springs so it's sitting a bit better now
As it was
Techno Pro Spirit coilovers with HTS insert, mine with MCN insert and AE86 strut with TRD spring and insert
As it sits now
jdm86gtz
Bought a Koyo rad from Sandy , fitted that to my Trueno and fitted my old Koyo to this
I decided to use a big port manifold and T3 adaptor instead of a cut'n'shut small port manifold
jdm86gtz
Postby jdm86gtz » Tue Jan 29, 2013 6:58 am
Got my front pipe back on Saturday. 9 pieces of S/S welded together. It consists of a CX Racing T25/8 to 3" V band adaptor, a 3" 90 degree bend, 2 3" 45 degree bends a few bits of straight 3", a 3" to 2 1/2" reducer and a 2 1/2" oval flange. I also got 2 lambda sensor bungs welded in, 1 for oem narrow band lambda and I'll plug the other for now but can fit a wide band sensor in it for a gauge in the future. The exhaust reaches as far as an AE86 manifold so I have a decat and Trust exhaust on the car for now.
Pity I have a crap wobbly hand
jdm86gtz
Postby jdm86gtz » Tue Jan 29, 2013 6:59 am
That's upto date for now. I have a few other things done and some still to do.
carbd7age
Postby carbd7age » Tue Jan 29, 2013 7:00 am
Awesome build, can't wait for action shots of this boosted sedan doin work.
Knockoff Crew member #0001
EJ86
Postby EJ86 » Wed Jan 30, 2013 11:20 am
I love this build. Amazing...
RuizXIII
Postby RuizXIII » Wed Jan 30, 2013 2:28 pm
Amazing work so far, man! This beauty looks real flash.
It's always nice to see a rusty car restored and brought back to it's former glory and better!
irony.cc
jdm86gtz
Postby jdm86gtz » Wed Apr 10, 2013 5:48 am
I contacted the chap who made my exhaust to make up an intercooler pipe for me and fitted the actuator.
I had to shorten the actuator pushrod so used the adjustable end of a Lancer GSR.
I took it for a spin and it's making 0.6 bar of boost
Evo 4 intercooler
Which is nearly invisible with the bumper and grill fitted
eTiMaGo
Postby eTiMaGo » Wed Apr 10, 2013 8:23 am
talk about a sleeper... love it!
0g buster
Postby 0g buster » Wed Apr 10, 2013 9:23 am
This thing is badd a$$. Props to you.
RuizXIII
Postby RuizXIII » Wed Apr 10, 2013 12:56 pm
Awesome Car!
How did you guys make that replacement sill? It looks spot on OEM.
irony.cc
jdm86gtz
Postby jdm86gtz » Thu Apr 11, 2013 6:12 am
A friend of mine is a fitter so he cut out a section and then bent up the sill repair in work.
The plan was sleeper so it seems to be working out ok so far.
boosted86
Postby boosted86 » Thu Apr 11, 2013 9:34 am
Great job bringing this car back to life. Awesome build, definitely fits into sleeper territory
Elvin Wes
Postby Elvin Wes » Fri Apr 12, 2013 12:33 am
Love this car!
jdm86gtz
Postby jdm86gtz » Fri Sep 20, 2013 9:24 am
I finally stopped putting it off and made up the instrument cluster from 4mm alloy which my friend then copied in 10mm timber (Walnut I think)
Rebuilt the 4 calipers as they were starting to drag a bit and get hot.
Also finally got my custom covers painted and fitted
In between my Trueno and friend's KE70
Postby oldeskewltoy » Fri Sep 20, 2013 10:13 am
very nicely done
HingaSPL
Postby HingaSPL » Sun Sep 22, 2013 11:20 pm
This is the kind of build I absolutely love. You brought that car back from the dead. Beautiful work
jdm86gtz
Postby jdm86gtz » Thu Oct 10, 2013 3:07 pm
Not much of an update. OEM style 4a-gte sticker looks a little crooked in the picture.
Also fitted an Innovate G3 wideband gauge, looks to be running high 11s on the gauge under boost but it's not in my eye line as it's only temporarily placed under the radio area.
joel23
Postby joel23 » Thu Oct 10, 2013 4:04 pm
looks good.. very clean....
axacharmant
Postby axacharmant » Thu Jan 30, 2014 8:10 pm
hi i just read your build i am to building ah 89 charm ant any tips on updating front suspension
jdm86gtz
Postby jdm86gtz » Fri Jan 31, 2014 10:29 am
I fitted a pair of 2" weld on coilover sleeves, cut the struts 40mm and fitted MCNSport dampers along with camber plates.
The rest of the front consists of polybushed arms/rods and P/S knuckles with Uras tie rods.
I fitted an adjustable Cusco tower brace from an AE86 (the AE86 strut tops are closer together so it has to an adjustable AE86 brace)
