I have the problem that with a cold engine my engine hestitates a bit and with a warm engine i hear backfire in the intake box.
Because of that i've mounted a fuel pressure meter and checked the fuel pressure. At idle with the vacuum hose disconnected it idles at about 40 psi, which is perfect (at least that's what's in the manual)
Any ideas on causes?
How long should it take for the fuel pressure to drop to zero after shutting down the car? Maybe that way i can check for leaking injectors or so? I have no problems though with starting the car. Only sometimes after a long quiet drive i have brown/black smoke when stepping on the gas.
Thanks!
